Prius C Aftermarket Stereo
Discussion in 'Prius c Audio and Electronics' started by Wharfe, Apr 20, 2012.
  1. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    I'm not sure it's literally plug-n-play, but it's certainly not expensive and it'll fit behind the head-unit in the dashboard. Also, for your needs, how about finding someone with a Prius C three or four that removed the factory Nav system?
    Yes, you'll need a line-level converter, as the factory head unit only has speaker-level outputs. Unfortunately I have no recent relevant experience with line-level converters. Perhaps check the reviews on Crutchfield and the like.
  2. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Finally there's face plate to cover the gap of the Aftermarked Head Units.
  3. Wharfe
    Wharfe Junior Member
    64
    Wow! Where can I order one?
  4. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    I'm waiting for final price quote and transferring funds. Min or order are 30 PCS.
  5. IanU
    IanU New Member
  6. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Taiwan and a minimum of 30 plates to order :S
  7. Mike D prius c
    Mike D prius c New Member
    Could any one tell me if I can put a kenwood DDX719 HU in my car, also am I albe to use the steering wheel controls if I put the HU in.
  8. Philipt99
    Philipt99 Junior Member
    30
    2023 Prius Prime
    SE
    Yes. Any double din will work and you can use the steering wheel controls if you buy the adapters. Either PAC or Axxess ASWC.
  9. Philipt99
    30
    2023 Prius Prime
    SE
    I will buy one... If you want to take a collection and make a bulk order that is.
  10. dolfanpete
    dolfanpete Junior Member
    60
    Naples, Florida
    I went to my local stereo garage where I just bought an amp kicker and 4 6.5's yo get a head unit but he couldnt find a face plate......SUCKS!
  11. Jt Torres
    Jt Torres Junior Member
    HB CA
  12. Philipt99
    30
    2023 Prius Prime
    SE
    No, I am looking for more of a stock look. I made my own but it still needs a little fine tuning and would prefer a kit.
  13. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Which one is that Head Unit?
    Is a PC3 so the mic, steering control, voice command, and usb work with that Head Unit????
  14. Philipt99
    30
    2023 Prius Prime
    SE
    It is a PC3... It is a Kenwood 9980HD. The mic didn't work out so well but the steering wheel control works and I got the adapter for the USB to function as well as the XM Antenna to work with my Sirius radio. I will be posting a parts list and pics very shortly.
  15. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    I don't know if this really works, taken from another webpage regarding the OEM Mic in a Aftermarket Head Unit.
    For the Microphone: I did a substantial amount of wiring, trouble shooting, building of power supplies, and legwork…to be beat by the OEM microphone amplifier. In the end I tried the simplest of things; I bypassed the Microphone amplifier and simply connected the factory microphone. This gave me a microphone that fit perfectly into the location and worked great. The OEM mic DOES NOT need the amplifier when used with the Eclipse head unit, and I can assume this is the same for all head units.
    I tested with a parrot mic and the Eclipse mic, both held in numerous areas of the vehicle, and in ALL cases the Toyota OEM mic was the clearest.
    To bypass the amplifier is easy, here it is:
    Behind the factory radio, on the k7 connector, connect the following:
    Toyota Brown wire = Tip + of a mono 1/8” headphone connector
    Toyota Yellow = Ring – of the headphone connector
    At the microphone in the headliner, Remove the mic and do the following:
    1. Cut the four wires between the plug and where they enter the wire bundle.
    2. Connect two pieces of wire to extend the Brown and Black wires, 3” works fine.
    3. Mask off or heatshrink the extra wires.
    4. Open the mic casing and expose where the mic connects to the amplifier.
    5. Solder the new wires to the circuit board where the mic connects.
    6. Connect Brown to the mic +, and Black to the mic -.
    7. Re-assemble the mic and install in the vehicle.
    8. Plug the mic into your head unit.
    9. Enjoy the factory microphone!!!
    I hope this helps others; it took a long time to gather all of the information. I will post other documents to support the wiring diagrams for the vehicle.
    vdefender likes this.
  16. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Is there any navi double din that:
    1. Use Voice command - If the VC button from the steering wheel works, and
    2. 100% wireless - how is posible that the standard radio could do this and most of the navi's depend on the cable.
    So far my favorite is the DNX6990HD, followed by the Pioneer AVIC-Z140BH with voice command, but if something else show up better. any idea?
  17. TxTkd
    TxTkd New Member
    16
  18. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
  19. vdefender
    vdefender Junior Member
    32
    Renton, Washington
    I just installed me avh-x3500bhs with the Metra kit. There are a couple little gaps I wish weren't there. My kit doesn't look like any of the pictures I've seen on here though.
  20. vdefender
    32
    Renton, Washington
    Also!!??? How do I get the factory mic to clip back in!? Lol I pulled it down and now it won't clip in because its like I need to get one hand above the head liner to push it back together
    Edit: You have to pull down the map lights, and stick your hand up above the microphone and push it back together.
