Prius c battery
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by zakky, Nov 5, 2014.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Explain the procedure, I would be very interested. The Prius C is the subject!
    #21 Andyprius1, Nov 10, 2014
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Look, I'm not going to waste my time copying a section of the owners manual and putting it here in a post.
    Read your owners manual.
    If you don't have one, get one.
    If PC is the subject, why does your profile show a different Prius model ??
  3. Andyprius1
    2,327
    859
    Cool CA
    My profile shows both.
    . All three are listed.
    #23 Andyprius1, Nov 11, 2014
    52,841
    hold the fob upto the start button.
    #24 bisco, Nov 11, 2014
  5. Easy Rider 2
    1,584
    258
    Ocala, FL
    Possible but only the PlugIn shows up with your posts.
  6. Andyprius1
    2,327
    859
    Cool CA
  7. bisco
    52,841
    you hold the fob up to the start button and push the button, no battery required. i don't know how else to explain it.
  8. vvillovv
    vvillovv Senior Member
    4,337
    1,518
    NY
    I googled it.
    It took about a minute to find another thread here that explains it fully, at least, to my satisfaction.
  9. Andyprius1
    2,327
    859
    Cool CA
    The Prius C does not have a start button, it has a ignition key which puts the car in Ready.
    My initial post had to do with the amazing quality of the 12 V battery. As I said, I had apparently killed the battery at least 5 times, and after recharging / jumpering everything is normal. That is a significant difference and improvement over the Gen 2 12v on my 2005 Prius. I was never talking about the FOB.
    #29 Andyprius1, Nov 12, 2014
  10. bisco
    52,841
    ah, sorry! interesting though, my '04 battery lasted 8 years.
  11. Andyprius1
    2,327
    859
    Cool CA
    Not a problem Bisco. I was hoping somebody else had observed the difference in the C battery. I think Prius Engineers gave the car a new fail plateau, allowing the battery not to drain so deeply, thereby saving its usefulness for next time. They probably made this improvement to all their Hybrids. Clever. Actually the same precautions they take with the HV battery.
  12. bisco
    52,841
    that would be a great thing. i wonder if it is possible to tell from the specs on the new yuasa batteries?
  13. Easy Rider 2
    1,584
    258
    Ocala, FL
    But then you WERE.
    And asking questions that you should have been able to answer for yourself.......having 3 of them no less.
    And then giving out bad information:
    My '13 C3 absolutely DOES have a start button. If any of them don't, I suspect it is only the 1 model.
    And finally, there have been several C owners here who have had trouble with their 12V battery and when the car is newer than 5 years old too.
    Your assumption about the C somehow having a better battery just doesn't make sense.
    If Toyota realized that there was a problem with the old brand/style of batteries, there is no good reason why they wouldn't change over ALL of their production, not just for the C.
  14. Andyprius1
    2,327
    859
    Cool CA
    I do not object to your opinions as long as they are positive. The objective of this forum is to educate not to criticize. I will be blocking you and urge others to do the same. You may crawl back to the wormwood.
    ANDYPRIUS ONE
    THIS. POST. IS. DIRECTED. TO. EASYRIDER. 2 YOU. ARE. BLOCKED.
    #. 39. POST. DIRECTED TO EASYRIDER. 2 . ONLY!
    . Whatever changes they made I think it's incorporated into the whole car. Remember, it was not very long ago ( Gen 2 ). When people were trudging down to the store for a new. 12 V. It would be nice if Toyota included the customer in the updating of these improvements. They never do.
    #34 Andyprius1, Nov 12, 2014
  15. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    the lower models C1 amd C2 have the key. the higher models have start button
    bisco and ztanos like this.
  16. bisco
    52,841
    they probably went with a power shutdown after so many minutes so the battery wouldn't drain.
    #36 bisco, Nov 12, 2014
  17. Andyprius1
    2,327
    859
    Cool CA
    TY. No wonder the confusion.
  18. bisco
    52,841
    can you start the c with the key with a dead fob?
  19. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Not the key. You hold the dead fob to the start button and it sends a RF signal to the car letting it know that you have the "code" to start the car.
  20. bisco
    52,841
    thanks, that's what i was thinking.
    ztanos likes this.
