Prius c Concept
Discussion in 'Prius c Main Forum' started by Skoorbmax, Apr 15, 2011.
  1. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    So this car should be closer to a ct 200h in size, height and much less weight.
    Also, does anybody know if this car will be unveiled at the 2011 L.A. Auto Show scheduled for Nov. 18-27.
  2. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I looked at the Youtube video - it doesn't look like anything we have here in EU - it is not a Yaris, not an Auris (similar in size though) - it looks more like a 4th gen Prius with a "chopped off tail"...
    Curious to see toyota.co.jp website when the "Aqua" will be out... :)
  3. pakitt
    2,173
    1,313
    Colorado
  4. pakitt
    2,173
    1,313
    Colorado
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Pics from the leaked brochure. It also said 1.5 liter HSD with 100hp. The car weights under 2,400 lbs. It weights about the same as the non-hybrid competition. It even weights less than the Honda Fit(?) mild hybrid.
    Fuel economy gained 16.5% under JC08 test cycle over the regular Prius. I guess we should expect 58 MPG in the US.
    New Toyota Prius C: Leaked Brochure Reveals Standalone Small Hybrid Hatch - Carscoop
    3 people like this.
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Dennis,
    Regarding fuel economy carscoop says
    So this looks like a 5% improvement (40/.38) over the regular Prius to me.
  7. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    With 100 combined HP and less than 55 MPG Toyota fails to find a niche for this car. It's not sporty and it's not super economical. It's JUST small.
  8. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I believe it is wrong. I was looking at the JC08 numbers from the brochure.
    Regular Prius is rated 30.4 km/L while Prius C is rated 35.4 km/L.
  9. xpcman
    1,302
    295
    So that would be 16% better making it 58 MPG for the US. Since the ICE is 22% smaller I would have thought they could have hit 60 MPG. Like the Gen III 50 mpg, the C at 60 mpg makes for good advertising.
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    I'll keep my fingers crossed.
    Unrelated -- where are the people who bitched and moaned over the split rear window in the regular Prius ? That should be reason enough to want this model ;)
  11. Cognato
    Cognato Junior Member
    I like the exterior. It looks like no climate control and 100hp seems way under powered. So how much does a Japan release tend to be different form the American release? I assume options like the headlight washer will not be in the American release.
  12. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Isn't this thing supposed to have the the same ICE/HSD setup as the standard Prius only mated to a shorter and lighter body?
  13. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Numbers from japanese to american test don't translate well. I would expect less than 58mpg, not more. Also the brochure says it is 1.339 L engine, which is smaller than I would expect in an Toyota american car.
  14. austingreen
    13,714
    4,232
    Austin, TX, USA
  15. austingreen
    13,714
    4,232
    Austin, TX, USA
  16. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    Okay, it's not a rebadged Yaris, but damn, i wish it was! It's hideous! Atleast it should be relatively efficient and 100hp is enough for a car of this size, although it's missing the trademark Prius gear shifter :(
  17. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    f expect it could do it in the city, but not on the adjusted highway figures. The smaller engine makes it tougher to get good highway numbers.
  18. ItsNotAboutTheMoney
    2,287
    460
    Maine
    The Jazz isn't a mild hybrid. It's a downsized IMA.
  19. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    1.339L is the competitor in the table, belongs to the Honda Fit/Jazz hybrid hood, actually.
    We can see the Prius c / Aqua holds a 1.497L ICE developing 54kw/74hp and 2 electric motors summing 45kw.
  20. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I sure hope so. It seems the gap between Prius and Prius C gets wider for more aggressive test cycle. It makes sense since the weight is so different. Going by that, 60 MPG is possible in EPA cycle.
