Prius C Converter/Inverter Coolant Bleed Procedure
Discussion in 'Prius c Technical Discussion' started by ugabuga, Feb 20, 2017.
  1. ugabuga
    ugabuga New Member
    TOmato Land
    2014 Prius c
    Thought this may help someone. Good luck guys.
    Side note - these instructions were sent to me from a Toyota tech after my TIS subscription expired. They are low quality screenshots from TIS. I have to say that if you are in a bind $15 for 2 day membership really isnt a lot.
    Also investing into a MCV cable so you can use the techstream software is also highly adviable if you are going to be fidling with the car.
      File size:
      128.1 KB
      File size:
      143.3 KB
      File size:
      133.2 KB
Loading...
