Prius C - Flasher Relay
Discussion in 'Prius c Accessories and Modifications' started by AzraelA, May 8, 2014.
  1. AzraelA
    AzraelA Junior Member
    Mars
    Some quick searches of the forums came up with two threads related to this issue. Both never really came to resolution on whether the C has a flasher relay or not.
    After 2 years of the C being on the market do we have a solution for hyper-flash with LED turn signals besides resistors or some module that appears only on Japanese websites?
    Has anyone found any wy21w or 7440 CANBUS LED bulbs that fit in the housings? I ordered some off ebay but the diameter was so big making them fit would stop the plug from locking in to the housing.
  2. -y0-
    -y0- Member
    140
    Pacific NW
    I never found one and just got the V-LED Triton v3s. They have built in resistors.
    Tyler Payton likes this.
  3. AzraelA
    Mars
    Which base adapter option did you got with for front and back? I notice the back turn signals use a round triangle like locking mechanism. The front flashers on the Prius C appear to use a standard locking mechanism.
  4. -y0-
    -y0- Member
    140
    Pacific NW
    I got the 7440 and used the rubber grommet from the OEM base and it fits perfect. It's really expensive though but it is bright as f like they advertised.
  5. AzraelA
    Mars
    Awesome, well this is definitely a good solution. Thank you very much.
  6. kingnba6
    kingnba6 Active Member
    1,007
    241
    NY
    i plan on getting the v3s for the front and rear too. but i really dont want to use resistors, its basically wasting energy, i really hope somebody can guide us to the flasher relay
  7. -y0-
    -y0- Member
    140
    Pacific NW
    You don't need flasher relays with the Triton v3s, they have it built in.
  8. kingnba6
    1,007
    241
    NY
    they dont have a relay built in, they have a resistor to get rid of the fast flashing when changing to leds. the resistor is a low class way of doing it. i would much reather upgrade to a led flasher relay.
    Dr_DLH likes this.
  9. -y0-
    -y0- Member
    140
    Pacific NW
    I know. I stated that in an earlier post. I'm saying you don't need a flasher and I don't think there is a relay on the C. I've taken it apart and looked at the usual spots.
  10. kingnba6
    1,007
    241
    NY
    and i also stated that i know they have resistors but if you know how resistors work, they are basically wasting energy. i would much rather upgrade the relay and get rid of that resistor that comes on the v3s.
  11. -y0-
    -y0- Member
    140
    Pacific NW
    I wish you luck in finding where the relay is, if there is one to replace. I agree it's better but fine with using what I have in the meantime.
  12. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    Wasting energy, LOL... Better not use headlights or turn your stereo or fan on either...
  13. Easy Rider
    Easy Rider Active Member
    982
    209
    N. Central Florida
    The resistors don't technically waste energy. Compared to OEM they use about the same.
    The "flasher" looks to be a part of a computer board and is NOT replaceable.
    The resistors are about the only option.
    What's the point of changing them out in the first place......if you can NOT put in something that uses less energy and runs cooler ??
  14. mertechperformance
    532
    126
    Nor-caL
    The look of them...
  15. kingnba6
    1,007
    241
    NY
    i dont understand whats so funny about my wasting energy comment? if you can avoid it, then why not? thats all i am saying. its the same thing as reving the engine at a stand still. why do it when you can avoid it?
    if the relay is onboard then its not even an option to change and the only way to go is either stick with halogens or leds with resistors.
  16. mertechperformance
    532
    126
    Nor-caL
    The savings would not even register by the time it hit the battery... It's not like the blinkers are ON constantly. or HIGH draw bulbs/units.
    -y0- likes this.
  17. Easy Rider
    982
    209
    N. Central Florida
    It would be MUCH better if you would "quote" the post you are commenting about so that we'all won't take offense when the comment was intended for someone else. :)
    I don't think your energy comment was funny exactly but the amount involved with turn signals is truly insignificant for most people.
    NOW.......take that tiny amount and multiply it times a few million cars and it becomes significant.
    I suspect that the car makers are slowly changing over to LEDs, mostly for aesthetic reasons, but it will have a small impact on overall energy use too.
    mertechperformance likes this.
  18. AzraelA
    Mars
    Wow this thread sure escalated into a heated discussion.
    I think the real problem here is that if the blinker control is controlled by the computer, Toyota should have built in an option for the dealership to recalibrate the computer to recognize lower power LEDs. It should be interesting as time goes by if we ever discover how to reprogram the computer, I suspect that'd be one thing we might see.
    Actually on that topic, has anyone attempted contacting Toyota or a service department to see if that can be done...? Curious idea me thinks.
  19. Dr_DLH
    Dr_DLH Member
    104
    I just located mine, it was a pain but if you take off the left panel, there is a white plastic housing for electronics and wires going in it that had a 10mm bolt on top and on the bottom, slide out towards you a little then way in the back up high is a blue relay that you can't get out, I tried so I squeezed the locking plastic and pulled down to unplug then plugged the new 8pin I got off eBay for 8$ shipped and all my led's don't hyper flash any more. I used the spot light 360 SMD Cree lights and they are super bright. Really like the led's!! Forget the load resistors it defeats the purpose of going led. Plus the load resistors get super hot and can melt or burn your car down.
  20. AzraelA
    Mars
    I'm concerned that your profile states that you own a 2005, as there was no PriusC prior to 2012. Can you please confirm whether you own a Prius (liftback) or a PriusC (hatchback)?
Loading...
