Prius C grid charger
Discussion in 'Prius c Main Forum' started by 14see, Mar 17, 2026.
  1. 14see
    14see Junior Member
    Nj
    2014 Prius c
    I have a 14 C. Couple months ago I pulled the HV battery and replaced a few modules with ones from a spare pack. They were not much better than the ones I replaced but it was what I had available. I equalized the modules after using a hobby charger to charge them individually. Worked fine for 5 months but now pa080 is back and there is a 40% delta SOC. I am thinking I might try a grid charger this time. I see tons of threads for DIY grid chargers for the 28 module battery along with the Meanwell LED drivers used in those applications. But I have not seen a thread with anyone listing which to use for a battery with only 20 cells. I know I need about 160v. I was looking at this adjustable unit HLG-80H-C350A.
    Can anyone who has done this please let me know what you used and what your procedure was. Thanks
  2. MWall
    MWall New Member
    Seattle, WA
    Hello,
    I have a spare grid charger, the one from Prolong Battery Systems. I have since replaced my battery with a lithium one, and don't have much of a use for it. I have the harness for it, too.
    Let me know if you're interested, and I may be able to get it to you.
  3. 14see
    14see Junior Member
    Nj
    2014 Prius c
    Yes I'm interested. I would send you a PM but
    "Your account currently has Private Messaging capabilities restricted due to account inactivity. Please contact the site admin if you would like these capabilities turned back on."
    I've messaged the mods but have not heard back.
    Send me an email
    [email protected]
  4. 14see
    14see Junior Member
    Nj
    2014 Prius c
    Replying again with you quoted just in case you missed the last message.
  5. PriusII&C
    PriusII&C Active Member
    432
    146
    San Jose, California
    In case you still need information of the grid charger, I built one with a Mean Well LPC-100-350 power supply. It works on both my Prius and Prius C.
  6. 14see
    14see Junior Member
    Nj
    2014 Prius c
    Oh interesting. I saw that people used that one for the full size battery but was concerned it might be too high of voltage for the c battery. How elaborate was your setup? I'll trying to keep mine pretty simple. Is a diode necessary to prevent the battery from cooking the charger?
  7. PriusII&C
    432
    146
    The LED driver is a constant-current power supply if the load voltage is within its specs (143-286 VDC for Mean Well LPC-100-350). For a heavily discharged battery pack, the voltage is below 143V anyway for both the Prius and PriusC. The driver's output voltage may jump a bit, but will pass that region very quickly. Then it will keep constant-current (about 0.35 mA) charging until interrupted, no matter at 240V+ for Prius or 170V+ for Prius C.
    Just like you, I was thinking to purchase a lower voltage LED driver for my Prius C. But it turned out the Mean Well LPC-100-350 works well for both my Prius and Prius C.
    I guess you don't have to have a diode if you always have the LED driver powered up before you connect it to the battery, and KEEP it powered up until you first disconnected it from the battery (maybe remaining power in the circuit has also dissipated). I don't trust myself that much so I wired 2 (Not one) diodes in series to protect the LED driver.
  8. PriusII&C
    432
    146
    The same setup was used for both Prius and Prius C, except that there is no power to the battery fan of Prius C because I could not control it.
