Prius c has worse mpg than Gen III on Fuelly
Discussion in 'Prius c Fuel Economy' started by Farfle, Jul 9, 2014.
  1. Brad K
    Brad K Member
    173
    53
    the Prius C proably only gets 41-43 mpg at 80 mph using cruise control on non-flat surfaces. It can get about 48-51 mpg at 70 mph. And 60 mpg at 60 mph. So how does that calculat into 46 EPA HWY
  2. fuzzy1
    10,452
    Did you read the article? The EPA and CAFE test cycles are not constant speed, but have specific speed vs. time profiles with multiple stops.
    Raw EPA figures, before the computations and rounding for the Monroney stickers, are posted at Download Fuel Economy Data. For the basic highway test, the 2015 'c' got 69.5848 mpg, vs. 69.6895 for the Liftback. At the moment I don't see the results of the other three tests, so don't know if they used the real 5-cycle or adjusted 2-cycle method, or exactly how the larger gap appeared.
    Note that to get the 54 mpg rating you suggest (or 53.5 before rounding), the raw highway test cycle result must be at least 74.31 mpg, under the old (1985-2007) EPA label rules. The under new rules (2008), an even higher test result is required to get that final label number, but the extra formula adjustments add more complexity.
    #102 fuzzy1, Apr 29, 2015
    Brad K likes this.
  3. skayaks
    skayaks Active Member
    123
    107
    Massachusetts
    Maybe this is old news, but I just noticed that Fuelly has a nice (new?) feature that presents results for each model year of a vehicle based on all fill ups for that model and year, but with outliers stripped.
    Since there were always some wacky tanks in the mix - like a Tacoma magically getting 70 mpg on a recent fill (I invented that example) - it makes it easier to compare average FE for different vehicles.
    PIPs are still blended with Liftbacks but there are a lot of outliers stripped in that case.
    ftl likes this.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    On my 2013, Prius C I have record mpgs of 97, 98, and 99.9.
    #104 Andyprius1, Jun 25, 2015
  5. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    How many miles are covered in each of those records, though? I'm going to speculate only a couple.
  6. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    The C will win in the city easy over the Liftback.
    Once your going past 69mph is were the C starts dropping over the Liftback based on tests.
  7. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    Perhaps that is why, after two months of ownership of a 2014 Prius c One purchased brand-new, and putting about 1,100 miles on it, I bought a lightly used 2012 Prius Liftback Two.
    The c is fine within my smallish city (population about 50,000), but the Liftback is better in every way outside my city.
    In my case, the Liftback is, hands-down, a better value.
    I enjoy driving the Liftback under all conditions. I enjoy the c only as a distant second choice.
  8. priusCpilot
    663
    210
    LA
    For me it's the opposite. We also have a Prius plug-in in my family and I prefer the C. Mainly because I prefer the dominion C over the heavier plug in. Much more responsive and tossible.
    #108 priusCpilot, Jul 13, 2015
  9. orenji
    orenji Senior Member
    5,887
    3,488
    Well, I like my C and will keep it for a very long time. It does everything I expected at the time of purchase, and more, now that I have had it for several years. Cars are like tools, you need to make sure you buy the right tool for the job. Sometimes you need more then one tool in the garage.(y)
    citroenjohn likes this.
  10. Dimitrij
    Dimitrij Active Member
    405
    202
    Virginia
    in another thread, there was somebody who reported 99.9 mpg over 500+ miles. He had done this to find out what the limits were and to prove the point, so not in the normal day-to-day driving conditions (I think his average mph was somewhere between 20 and 25, so it will have taken a whole day of careful driving).
    On occasion, in good weather and in no hurry I have clocked in excess of 90 mpg, driving across our city for 5-10 miles, but even without trying too hard it's in the upper 80s.
  11. vinnie97
    1,430
    277
    Somewhere out there
    Yes, and he was hypermiling for the sake of a competition here (username of ufourza or somesuch), but getting over 90+ mpg beyond a few miles is atypical. I would wager I probably have close to your average mpg on my 2012 C. Traffic (stoplights specifically), terrain, and weather can all result in significant hits in fuel economy, I've found (perhaps more so than the liftback).
  12. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    Exactly! (I suspect many people ignore the smaller frontal area of the C when considering the meaning of the .28.)
  13. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Actually Fuelly shows higher MPG for C?
    This is a printout from your fuelly links, one year later
    orenji likes this.
  14. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    My C is getting higher mpg than my Gen II.
    See my Fuelly results below.
  15. usnavystgc
    3,159
    990
    Tucson, AZ
    The C will beat the Gen II hands down.
  16. orenji
    5,887
    3,488
    The C is the winner :D:D(y)(y)
  17. cyclopathic
    3,292
    547
    2014 Prius c
    C MPG seems to suffer more from low temps and break-in. My C averaged 42MPG for 1st 130mi. With 15.5k on the clock it is at 59.3 indicated for last 5500mi now. So I wouldn't be too concerned with new year model MPG low at the beginning.
  18. Oldwolf
    826
    110
    NC
    2016 Prius v wagon
    Even though Fuelly calculates 55.5 mpg for my C, the computer consistently tells me my mpg is averaging 57+ mpg.
    Both my Prii computers are optimistic.
  19. cyclopathic
    3,292
    547
    2014 Prius c
    On mine the diff ~2-2.5MPG real vs calculated. This is pretty normal for all Priora and all cars in general.
  20. Oldwolf
    826
    110
    NC
    2016 Prius v wagon
    I've kept track of the errors on both cars since I have owned them.
