Prius C heated seats
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Angelana, Sep 14, 2017.
  1. Angelana
    Angelana New Member
    Indiana
    2016 Prius c
    I just got a new 2016 Prius c and had seat heaters installed. I love them but they are very inconsistent with heat. They cycle on for anywhere from 6-15 minutes then off from 8-15 minutes. They go completely cold. Then come back on uncomfortably hot! This is not what I paid for! Service department says that is within specs for cycling, the seats heat to 100 degrees. I can switch them from high-low-off. I have it in the shop now, I need it fixed before winter. Frustrating!
  2. Angelana
    Angelana New Member
    Indiana
    2016 Prius c
    Update.. After having my car in the shop for 4 days only to be told the erratic cycling is normal... I finally have an answer! Apparently in February 2017 a new safety plan was started with the seat heaters. The seat heats up to 100* then automatically shuts off until the seat reaches 40*! There are sensors in the seat backs and bottoms, which explains why they kick off at separate timing intervals. Stupid, right? HOWEVER... If you put the heater on LOW, it will stay on indefinitely! Too bad the dealer wasn't aware of this 4 days earlier. Ugh.
    Sean Nelson likes this.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    At least you have a low setting... mine is on or off and it does the cycle... :(
  4. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I guess the intention is that you use "high" to get the seats warmed up initially and then you switch it to a lower setting once it feels comfortable. Thanks for posting this, I don't have heated seats in my Prius C but I intend to get them in my next car and I can imagine that knowing this could be quite useful.
  5. Oldwolf
    Oldwolf Prius Enthusiast
    816
    106
    NC
    2016 Prius v wagon
    My C4 has factory heated seats, and yes, they cycle. Every 15 min or so when I feel my butt getting cold, I hit the on button again!
    On the other hand, my 2016 V Level 4 also has heated seats. IMO, they get a bit too warm. Sometimes I have to turn the seat heaters off.
