Prius C Highway Wind Noise
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by 751woodbine, May 18, 2012.
  1. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    would you post pictures of your setup?
  2. CSuirp
    CSuirp Active Member
    202
    118
    US
    2014 Prius c
    Here are some crude pics of the job on driver door. Is the same on the rest...even hatch. Hope it helps ya.
    frenzee likes this.
  3. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    THANK YOU, GREAT PICTURES it really helps. where did you get the insulation? auto parts store?
  4. CSuirp
    202
    118
    US
    2014 Prius c
    Glad to help when i can Bob! I got the insullation off Amazon. Here's the description name on their site: "33Ft Long Self Adhesive Automotive Rubber Weather Draft Seal Strip Weatherstrip For Car Window Door Soundproofing Engine Cover(B Shape Total 2Pack 10M)"
    1 pack has 2 rolls. Get 2 packs and it will cover ur 4 doors and hatch. Left over after can be used for under hood sides a bit or whatev u choose. Make sure u have some 70% alcohol when u run out of the adhesive wipes they give u. Wash application area good and dry good. Apply the adhesive aid (or alcohol if ur out of adhesive aide) and then mount moulding carefully because once it hits metal...not easy to reposition. Have fun!
    priustexasbob likes this.
