Prius c Homelink mirror install instructions
Discussion in 'Prius c Accessories and Modifications' started by managerman, Sep 10, 2012.
  1. managerman
    managerman Prius v Nerd
    228
    110
    Columbus, OH
    Hello!
    I finally installed a Homelink Auto Dim mirror in my Prius c. I have attached a PDF with pictures and step by step instructions. Installation took about an hour. (It was my second install - since I had previously installed one in my Prius v)
    Please feel free to ask any questions. Good luck on your install!!
    -M
    Here is the link: ---> Prius c Homelink Install
    Hawkeye63 likes this.
  2. Native2PS
    Native2PS Member
    144
    65
    Kihei, HI
    excellent instructions, thats pretty much how I did mine, except I tapped different wires but with the same result
  3. daboy
    daboy Junior Member
    51
    I think you should tucked the wires to the other side ( a pillar), if you remove the black rubber you can see the wires are blocking the airbag.
  4. icspots
    icspots Junior Member
    What daboy said. I realize this is an old thread, however I'm waiting for the auto-dimming mirror to come in for my wife's '12 PcIV. Routing the wires like that from the headliner and down behind the rubber gasket puts the wire directly across the deployment path for the airbag. You should never put something across the airbag path. On the one hand it could keep the airbag from deploying properly and injure you by lack of the airbag being where it should. On the other hand it could propel the object (and granted a wire isn't much of an object) into your head.
    Removing the pillar trim in a car isn't all that hard and is by far the best way to go about doing this type of install.
  5. dengar100
    dengar100 Junior Member
    22
    Queens, NY
    I know this is an old thread but I wanted to chime in. I just followed these instructions (with minor changes) with success. I have a 2013 Prius C 3 and my mirror only dims (2 wires red and black). The only differences were that on my box the fuses were the opposite of what you said (the first one I tried was battery, the second one was ACC). I also took the A pillar cover off and routed the wires up there, behind the airbag. Thanks for the detailed write up!
    iPhone ?
  6. SamanthaC0716
    SamanthaC0716 Active Member
    333
    115
    Does anyone have a part number for the auto-dim mirror?
    iPhone ?
  7. dengar100
    22
    Queens, NY
    The one I bought (auto-dimming only, no homelink, no compass) is model number Gentex 50-GENK2AM. I bought it from here: http://www.autopartswarehouse.com/sku/Univ/Gentex/Rear_View_Mirror/GTX50GENK2AM.html
    After purchasing I read up on it more, and it seems pretty much any auto-dimming mirror will work and many people have success buying whatever they can grab off e-bay.
  8. SamanthaC0716
    333
    115
    Thanks. Looks like the one from a Prius v is Toyota part number 87810-0W570. Comes up as VERY expensive when you search for that part number, but used mirrors are going for around $50-70 on eBay. I don't see many of them including that little pigtail connector, though.
    iPhone ?
  9. SamanthaC0716
    333
    115
    Considering adding an autodim mirror again and noticed the PDF from the original post is not available. Does anyone have it or similar instructions?
    iPhone ?
    jcarmona likes this.
