Prius C in the snow?
Discussion in 'Prius c Main Forum' started by tnt4him, Nov 3, 2015.
  1. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I'm pretty happy with the Michelin X-Ice XI3 tires I put on my Prius C a couple of weeks ago. I bought them because they received a good rating from Consumer Reports.
    Vancouver has recently had one of it's rather rare snow events, and I've been out in the evening in just-below-zero weather shooting photos of Christmas lights. The Prius C with the Michelins went up roads with probably about 6% grades that were covered with compacted ice-ish snow without missing a beat. They've also proven to be quite quiet on wet or dry pavement, which I appreciate. The only downside is that Consumer Reports rated them less than average for wet traction, which is important here in the rainforest.
  2. LasVegasaurusRex
    LasVegasaurusRex Active Member
    234
    110
    Las Vegas, NV
    just be careful with the pedal, HSD introduces a lot of torque steer.
  3. Sean Nelson
    421
    182
    If you're driving in the snow or on ice and you're being affected by torque steer then you're not driving properly. Easy does it is the way to go, both for accelerating and decelerating.
  4. rhodeislandhntr
    rhodeislandhntr Junior Member
    29
    Small amount of snow this morning, stock tires and first time with the C in the snow, it handled it great. The others drivers are the issue. Might get another 4 to 8 inches tommorrow, will try it again then.
    michael.sfo likes this.
  5. Sean Nelson
    421
    182
    Yeah, when traffic on the arterial streets seizes up I find that it's a lot faster to take the side streets, even if they're not cleared. I've yet to find a street that the C with snow tires can't handle.
  6. Mendel Leisk
    42,343
    Yeah, it was nice to have a more-or-less white Christmas for a change.
    Purely editorial: I hate that term the weather officials have: "snow events". Similarly there's "rain events", "arctic outflow events", and others. "Vancouver had some snow" works too. We've gotta fight back against officialdom verbosity, lol.
  7. spitfire2674
    spitfire2674 Junior Member
    scranton
    2016 Prius c
    I have the same car. I am one terrible scaredy cat, and haven't driven mine yet since purchase of 4/2016. i let it sit and let someone else do the driving. what am i doing wrong. i need the right tires i think.
  8. rhodeislandhntr
    29
    Drove mine in the last 2 storms, stock tires, slow and easy, car handles better than my 2015 4wd silverado. I never felt like I wasn't in control.
  9. MarsiaMS
    MarsiaMS New Member
    Winnipeg
    2016 Prius c
    I traveled all over Northern BC and a bit of Alberta with my Prius C and studded tires. Never was stuck, never ended up in a ditch. A bit of snow os fine, although cannot get through a thick layer of snow. This was never a necessity though. While it snows a lot up here, roads are always clear enough for my Prius.
  10. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Thought I’d add to this old thread.
    Simply put, im pleasantly surprised at my C’s performance tonight. 5” on the roads now and not yet plowed with snow still coming down fast. Add to that a layer of ice underneath.
    While it took me almost an hour to get home at a distance of only 8 miles (I couldn’t see more than 25ft max it’s snowing that hard) the C performed excellent on stock all weather tires.
    I passed a total of 6 vehicles and 1 snowplow in the ditch. Even found myself in the oncoming lane when I reached a lit portion of the road! (As I said, I couldn’t see). I guess you could call it white out conditions at night.
    Maybe I will keep this thing once the mfg’s Warranty is out who knows. lol
    michael.sfo, ztanos, skayaks and 2 others like this.
  11. Mendel Leisk
    42,343
  12. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    No - still has the OE Bridgestone's on her. We get snow like this once, maybe twice a year in my area. Snow tires wouldn't be worth the purchase.
  13. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    It handles ok for short wheelbase but I would definitely avoid older model without disable ESP button. Toyota has one of the worse ESPs in industry easy to get stuck.
    #53 cyclopathic, Jan 21, 2019
    Andyprius1 and ztanos like this.
  14. skayaks
    skayaks Active Member
    123
    107
    Massachusetts
    I have a '13 C (without "disable ESP button"). I believe traction control tuning for all years of the C is less restrictive than the Gen 3 Prius. (And definitely better than Gen 2.) Although the traction control light has flashed at me many times in the snow, it has yet to cut power in a way that interferes with my uphill charge.
    dubit and ztanos like this.
  15. cyclopathic
    3,292
    547
    2014 Prius c
    There's a way to disable ESP on pre-15 which involves turning car off and it makes big difference if you get stuck look it up.
    As far as software goes the Toyota's ESP in general vastly inferior. I had an opportunity to drive side by side C and son's Mitsu Mirage in freezing rain huge difference even if he had worse tires. Didn't even have to turn ESP off just right amount of slip.
    I live in state where studs/chains are illegal and with as often as we have snow hard to justify snow tires with second set of wheels, so drive on all-seasons.. makes big difference.
    #55 cyclopathic, Jan 21, 2019
    ztanos likes this.
  16. skayaks
    123
    107
    Massachusetts
    Yes, I have that procedure in my glove box and have confirmed it works. I haven't needed to use it on the road (yet), but I do use snow tires in season.
    ztanos and Mendel Leisk like this.
  17. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Extra Sensory Perception ???
  18. cyclopathic
    3,292
    547
    2014 Prius c
    Sort of.. Electronic (in)Stability Program.
    I have tripped it a few times in dry coming around curve very unpleasant experience. Very intrusive almost caused crash by applying brake/retarding engine.
    #58 cyclopathic, Jan 21, 2019
    ztanos likes this.
  19. Andyprius1
    2,327
    859
    Cool CA
    Iv never had any problem with skidding, I just leave the ESP on all the time. In Brake position the car will always slow down, if your foot is off the go pedal. Should inertial forces throw your body to a hard left or hard right, you may be taking the turn too fast. I drive on a very slippery, dangerous and mountainous road with a
    altitude of 1000 feet. People often cross the double yellow line coming toward me, that’s frightening.
  20. Andyprius1
    2,327
    859
    Cool CA
