Prius c is 'Aqua' in Japan. Will return 94mpg japan cycle (61 us)
Discussion in 'Prius c Main Forum' started by slayerhk47, Sep 28, 2011.
  1. sharol46
    sharol46 Junior Member
    89
    kansas
    It actually became available toward the end of the model year. When I ordered mine in March, it wasn't available. The dealer called me in September or October and said it was available as an after-sale add on since it was becoming available in the later builds. It was not available in March.
  2. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I want one. :p
  3. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    Hmm, another GenII '07/50,000 miles owner thinking about the c.
    Here's what I like about my GenII (April 07) over the c
    53/57 mpg (winter/summer) I don't see 65 mpg as a major improvement.
    Backup camera
    MFD
    Speed console near the driver's seat (not at the center)
    Quiet (function of size)
    Value 15,500, paid off.
    Here's what I don't like about my GenII compare to the c.
    Driver's seat/position/seats/lack of telescopic steering wheel.
    Older, odd looks.
    Mechanical issues with many pumps being somewhat problematic
    Battery fan unprotected/no filter
    Conclusion: I am thinking of adding aftermarket seats on my GenII to make it feel newer :)
  4. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Your car is rated at 46 combined. If you're pulling 9 more than that due to driving habits you would expect a car rated at 61 mpg to do substantially better than that--closer to 70 I should think.
  5. ystasino
    793
    50
    Tucson, Arizona
    Hmm, my guess is that it will not be that simple, particularly because my mpg is a function of a specific highway/city mileage ratio, not some 35 mph gliding routine.
    We don't know how the shortened c will behave on the highway and my guess is that, given how smaller cars struggle with aerodynamics at high speeds, mpg gains on the highway will be modest. Instead the reduced weight and more efficient Gen III engine should help with gliding in the city.
  6. talonts
    talonts VFAQman
    468
    76
    I'm curious, where do you get this idea from? A smaller car generally has a smaller CdA, which means less power is needed to push it through the air. Which generally means better mpg for the same size motor (especially with lower weight).
  7. pudgie_child
    pudgie_child Junior Member
    17
    Mission Viejo, CA USA
    It is generally thought that it is more difficult to make shorter cars (lengthwise) as aerodynamic as longer cars. And, as you likely know, aerodynamics plays a greater role in fuel efficiency in highway driving than it does in stop-and-go driving.
    (Why Do Subcompacts and Compacts Get Such Similar Mileage? - KickingTires)
    In most cases . . . compact cars are significantly larger, heavier and more powerful than their subcompact siblings. Why then is their gas mileage so similar? At the auto show, I posed the question to automakers and analysts. The simple answer: aerodynamics.
    “Keep in mind that technology will help both [highway and city mileage], but not at the same rates,” said Mike O’Brien, Hyundai’s vice president of product planning. “The city number is going to be the bigger difference when you go a class up in car size.”
    Conversely, the fight for better highway mileage goes against what O’Brien calls “road load,” a combination of the vehicle’s frontal size, tire friction and drag.
    In some cases, it’s actually harder to eke out better highway mileage in a subcompact car, said IHS Global Insight analyst Aaron Bragman.
    “When you have a B-segment [subcompact] car, it’s very hard to make it aerodynamic, given how short it is and how many of them end abruptly,” Bragman said.
  8. Skoorbmax
    2,641
    265
    Western NY
    That makes sense, but is a relative comparison still; even though he says "it's actually harder" I cannot think of a subcompact at this time that gets inferior mileage to its compact brethren of the same vintage. I do see on fueleconomy.gov that the accent is not rated any better than the Elantra, though.
  9. ystasino
    793
    50
    Tucson, Arizona
    The point is that the gain in mpg from lower weight will be more evident in lower speeds than in highway speed. So the c is more likely to offer significant mpg advantages to those who drive in the city than on the highway. I don't think it will be "worse" on the highway because the weight reduction does help. But it doesn't help as much because of the lack of improvement on aerodynamics.
  10. Trollbait
    12,543
    Just compare the Prius and CT200 fuel economy. They have the same drive train and nearly the same weight. Different wheels and tires play a part, but most of the economy difference is in their shape. That larger rear area on the CT200 means a larger low pressure zone that can actually pull back on the car as it moves forward.
    Those two are also close in length. The c will be shorter which gives less length for a kammback to be effective while maintaining cargo and rear passenger space. The Honda CRX, Insight, and CRZ pull it off by dropping the rear seat. Sedan versions tend to have a better rear aero than their hatch siblings because they don't have a square end.
    Hatchbacks are great for utility, but they can have nearly all the areo penalties of a SUV.
  11. Gokhan
    Gokhan Senior Member
    6,241
    2,473
    Paramount CA
    I correct myself. The amazing aqua color is actually available in all trim levels but the L trim level comes only in aqua. :)
  12. edmcohen
    edmcohen Member
    133
    25
    Newark DE
  13. AquaJan
    AquaJan Junior Member
    47
    17
    US
    Now they're (TMC) saying 83mpg
  14. AquaJan
    47
    17
    US
  15. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    The 94 mpg quoted in the title of this thread was referring to the 10-15 cycle.
    In Japan, they have two tests cycles:
    The (older) 10-15 cycle in which the aqua returned 40 km/l (about 94 mpg), and the (newer) JC08 cycle in which the aqua returned 35.4 km/l (about 83 mpg).
  16. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    My poor math skills says there's a (crude) .65 conversion factor going from JC08 to EPA. So the latest 83mpg figure released from Toyota converts to (drum roll): 54mpg. :eek:
  17. austingreen
    austingreen Senior Member
    13,677
    4,214
    Austin, TX, USA
    Yeah, that should be ballpark, but ... from the rumors the highway engine will be less efficient on the highway portion than the current 1.8L. The cd is 0.28 so even with a smaller frontal area it should have a higher cdA. I'm guessing the highway miles won't exceed the gen III liftback's 48mpg, which will leave us with a combined mileage around 52mpg.
  18. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Of course, that's just the EPA mileage. The smaller displacement should allow much better mileage for drivers who keep their speed down.
  19. TwoBear
    TwoBear New Member
    28
    Milwaukee, WI
    Interesting that they don't mention anything about a sunroof. They seem to be showing one in the pre-production promos here.
  20. austingreen
    13,677
    4,214
    Austin, TX, USA
    Just an educated guess at EPA. We should know the real numbers soon enough. The prius c should get better lower speed mileage because lower weight.
    On the smaller engine displacement getting better milage, that would be only if all things were equal, and that is not likely the case. The 1.5l appears to be largely unchanged from the prius gen II, and the gen III engine is more efficient on a range of power levels. Toyota can update the 1.5L and make it more efficient on a future version. I hope the bsfc curves are out soon, the we will know if the improved egr or other things were done to make 1NZ more efficient. It is a less expensive, lighter, and smaller engine. A combination of these reasons may be why toyota chose it, but I would suspect lower cost for it and the rest of the hsd.
    You can see on the graph the 1.8L gets 220 g/kwh over a range as big as the 1.5 gets 230 g/kwh. The 1.8L engine is more efficient at lower power levels, and quieter at higher power levels.
    http://ecomodder.com/wiki/index.php...n_(BSFC)_Maps#Toyota_Prius_1.8L_2ZR-FXE_2010-
