Prius C lifted, larger tires
Discussion in 'Prius c Main Forum' started by Jstampfl, Jul 5, 2023.
  1. Jstampfl
    Jstampfl Junior Member
    25
    Mongolia
    2018 Aqua
    I
    I have been reading priuschat for a month. I just bought a 2018 Aqua with 155,000 km.
    It came with 185/60R15 tires. I had it lifted about 1.5 inch. I drove about 2000 km. Mostly on asphalt. But 400 km on dirt and stone (kind of like gravel, but natural assortment so 2 or 3 inch diameter or bigger are mixed in.) Mostly unmaintained.
    I bought some tires. Used but pretty good condition.
    Front: 255/65R15 32 psi.
    Rear: 195/65R15 30 psi.
    Got an alignment.
    Drives very nice. Very minor rubbing when turn right when parking. Normal driving no rubbing.
    Speedometer was over by 8%. Now over by 1.5%.
    Odometer was under by 1.5%. Now over by 8%.
    I am using a GPS speedometer app to compare the speed and fistance.
    GPS 191 km.
    Trip meter 206.5 corrected by 8% = 191 km.
    Asphalt 2 lane highway. Rolling hills. Half the trip East and the other half West on the same highway.
    Fuel used (92 octane) 6.44 liters.
    30 km/l = 70 mpg.
    Trip meter showed 26.3 kml avg.
    Drove in D all the way. Didn't need to use the brake to slow on any downhill dips.
    I tried to stay close to 80 kmh. (+/-5).
    The reduced engine speed was much quieter.
  2. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    omg I would really like to see some pics
    bat4255 and TGrracie like this.
  3. Mendel Leisk
    42,263
    Yeah, preferably with the hatch fully loaded. :)
  4. Jstampfl
    25
    Mongolia
    2018 Aqua
    I
    Note, in Mongolia 80 kmh is max speed on the highway.
  5. Jstampfl
    25
    Mongolia
    2018 Aqua
    I
    Roqu3 likes this.
  6. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    Well it looks very nice, I thought those 255 would look way bigger than that
  7. Jstampfl
    25
    Mongolia
    2018 Aqua
    I
    Sorry. Typo
    Front: 205/65R15
    Roqu3 and Mendel Leisk like this.
  8. Jstampfl
    25
    Mongolia
    2018 Aqua
    I
    2018 Aqua
    Front: 205/65R15
    Rear: 195/65R15
    The Aqua has 15 x 5.5 rims, so a 205 width tire will fit.
    The Prius C has 15 x 5 rims, thus can't use a 205 width.
    A 195/70R15 is about the same diameter as the 205/65.
    The 16 inch rims on the Prius C is 16 x 6, so 205 width fits.
    If you want wider tires, don't forget about tire chains.
    The 205/65 tires rub just slightly when turned completely right or left
    Just drove about 100 km on some dirt/rocky roads. No rubbing handles nice, feels better.
  9. Jstampfl
    25
    Mongolia
    2018 Aqua
    I
    Stand corrected;
    Both Toyo and Yokohama say 205 width on 5" width rims
    "The 205/70R15 Yokohama AVID TOURING-S has a diameter of 26.4", a width of 8.2", mounts on a 15" rim and has 787 revolutions per mile. It weighs 22.4 lbs, has a max load of 1499 lbs, a maximum air pressure of 51 psi, a tread depth of 10/32" and should be used on a rim width of 5-7".
  10. Jstampfl
    25
    Mongolia
    2018 Aqua
    I
    Just checked the rims. They are 15 x 5j on my 2018 Aqua.
