Prius c Maintenance Schedule
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by usbseawolf2000, Mar 6, 2012.
  1. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    Most of what I see, pad wear is very minimal by that mileage, even our stop and go traffic. Problem with the Toyota hybrids is that the brakes are often neglected due to such low pad wear. At 120k, I would not replace the pads if they are in good shape, but I would certainly pull and inspect them, lube the slide pins, etc. Many people fail to realize there is a lot more to brakes than just the pads.
  2. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    Had my state inspection at 118,000 miles a few months back, and was fully expecting to be told I need new pads as I am still on the originals. Like a dealer, my repair shop never fails to mention upcoming maintenance, but it passed without a word. Amazing technology that it can still stop the car and not wear the pads as quickly. Plus there's the added bonus of no brake dust on the wheels.
  3. Mendel Leisk
    42,343
    I'll have another brakes kick-at-the-can: it's easy to get complacent, conflate "brake pad thickness" with "brake inspection". The US Warranty and Maintenance Booklet for the Prius c has the following two instructions:
    This "visual" inspection is every 5K miles, basically a look-over while the tires are being rotated. But then, every 30K miles, there's:
    Considering the c has rear drum brakes, the above description is a little off-base. But the intent is clear:
    Visual inspection every 5K miles, except full inspection, every 30K miles. The latter entailing a caliper pull-off, clean up of pads/shims, relube of all contact points and the caliper guide pins, and check rotor thickeness/runout. On the rears the drum should be inspected, drum ID compared to spec (which I don't have :(), the shoe condition/thickness inspected, and the shoe contact points with backing plate relubed. There's other contact points, the lube on them is tricky to get to, and tends to last.
  4. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    Hello! I made this and hope it is useful to y'all. I've created a Google Sheets that has all of the regularly scheduled maintenance that you've mentioned here. I have the maintenance going up to 1000K (because why not).
    Let me know if I missed anything and I can add it.
    Click Here to See The Chart (Google Sheets)
    P.S. I don't frequent this forum that often but since my Prius C's Hybrid Battery died I thought I'd stop by. Not looking forward to spending $4k for the battery (plus tax and labor). Battery died at 125K. :(
    #64 legoadan, May 29, 2023
    Pri3C and Mendel Leisk like this.
  5. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    legoadan likes this.
  6. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    I did end up going that route. That buyer too.
    My first rebuilt just failed and I decided to switch to Lithium. My car has the new Lithium battery in since Saturday and it feels amazing! So glad I switched! Time will tell if it's worth the longevity, but from what I've heard online I think it will!
    Roqu3 and Pri3C like this.
  7. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    I've been noticing that these forums are a dying medium and link rot (when a cited webpage becomes unavailable) will eventually become a problem, so I'm posting the same data that is in the Google Sheet in this forum as a CSV (comma separated values) and as a link to a pastebin with the same CSV. For the future, any version of excel, google sheets, or other spreadsheet software should accept CSV data very easily.
    (PASTEBIN LINK)
    Roqu3 likes this.
