Prius C noise rolling in neutral
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by vikisonline, May 30, 2018.
  1. vikisonline
    vikisonline Junior Member
    ontario
    When my car is rolled in neutral it makes a weird noise.
    It seems to make this noise at high speeds when coasting too,
    though it has to be done just right and is fairly hard to reproduce.
    Any ideas what it could be?
    52,769
    any idea where it is coming from?
  3. vikisonline
    ontario
    transmission or drive shaftmif i had to guess
    52,769
    maybe a cv joint or axle shaft.
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Usually neutral only is a transmission issue. But since you state it's also at high speeds while coasting, it's hard to determine.
  6. vikisonline
    ontario
    hmm. well hopefully warranty covers it. will find out what it is tuesday :S
  7. bisco
    52,769
    all the best!(y)
  8. vikisonline
    ontario
    Noise in video was deemed normal.
    There is an other noise from the centre baffle. they said that could replace it for 1500 bucks but not worth it.
