Prius C Oil Filter
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tonyk81, Mar 12, 2012.
  1. tonyk81
    tonyk81 Junior Member
    25
    Utah
    I am just curious if someone has the Toyota part number for the Pruis C oil filter.
    Not seeing this model on any Toyota parts site, or on third party sites yet.
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Why not inquire at your local dealerships parts counter?
    Posted from my iPhone via the Tapatalk app.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    It should be written on it, it is an external filter yes? Probably a -YZZF2
  4. tonyk81
    25
    Utah
    I did ask the local dealership. They said they were unsure. I asked how they would change the oil under the complimentary plan. "I guess we'll have to figure it out then." Doesn't instill much confidence in a person.
  5. Mendel Leisk
    38,644
    Brand new model, there won't be demand for this info for a few months. It might just be identical to regular Prius, ie: just a paper cartridge in a reused housing.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    That's not a good answer is it, he should have said "I'm sorry I don't know but I'll find out and let you know". I would make sure they know what kind of filter to use and that they have one before you take it in for your first oil change. Otherwise they might not have one and it won't get changed. Also make sure they know what oil to use, almost certainly 0W20, your owner's manual will confirm that.
  7. tonyk81
    25
    Utah
    Asked again today, service advisor says "it's not your business to know since we'll be changing it anyway. I'm sure we got the right one lying around here somewhere." When questioning them to ensure they use the right type of oil and what kind he said "well we're certainly not using Toyota Genuine for these freebie changes. We'll use whatever we have surplus of that will work on your car."
    I emailed a complaint to the Owner Stephen Wade and he just said "everything the service advisor told you was correct, and you'll need to discuss any further issues with them."
    Looks like a dealership I'm going to avoid. Although they are the only Toyota dealership within 130 miles or so. I guess I'll either get my free oil changes at one in Vegas when I'm there occasionally or just do it myself.
    SILVERCwSUN and alimoeeny like this.
  8. tumbleweed
    4,067
    687
    Eastern Oregon
    There are certainly a lot better dealers than that around. You might consider letting Toyota customer service know, they probably won't do anything but if enough people complain, maybe they will.
  9. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    WOW, just WOW!
  10. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Come on! Just open the hood or get underneath and LOOK at the filter. It should have a number on it. 4 cylinder Toyotas with external filters take a 90915-YZZF2. Who do you expect to know your car better, you or the jerks at the dealer? By the way, find another dealer.
  11. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Only problem is one has to go over 100 miles to find the other nearest dealers (Vegas).
    This is the same dealership who wouldn't implement either of the engine knock (on cold soak)/engine vibration on startup TSBs for my Gen III (now traded in).
    Looks like we have a real winner, Tony. ;) Ugh.
  12. tumbleweed
    4,067
    687
    Eastern Oregon
    I would forget about the "free oil changes" buy some filters and drain plug washers on line and change it myself. You can get Mobil 1 0W20 (some other brands as well) at Wal Mart or an auto parts store, or order the oil on line also.
  13. Mike500
    Mike500 Senior Member
    2,593
    764
    More likely than not, it will be the same oil filter as the GenII Prius, since it uses the same 1.5 liter engine as that Prius.
  14. vinnie97
    1,430
    277
    Somewhere out there
    Tumbleweed, I would but I have bilateral elbow tendinitis, so I'd rather not exacerbate it. Next bet is to find a local trustworthy mechanic...
  15. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Order a package of filters online, take it to walmart, specify the M1 0W20, hand them the filter. Forget this dealer forever.
  16. Mendel Leisk
    38,644
    With the US schedule spec'ing one filter change per year, for DIY at least I'd just pick up a single filter from the dealership (if they ever figure out what it is...). D.O. for the oil: more-or-less the cheapest 0W20 going is Toyota's. Why commit to a decade's worth of oil changes on a car you might trade in, total, etc.?
    Vinnie, I had tendinitis problems, and what worked for me was taking on more and varied activity.
  17. vinnie97
    1,430
    277
    Somewhere out there
    well, the work I do exacerbates it already, so variation could be part of the solution. Obviously, stretching and exercise is important, but I've had this ongoing 7 years now. About to visit a chiro (once bills are pared down) and have some active release therapy implemented (I've tried many other modalities, including sling, magnet therapy, acupuncture, ultrasound, physical therapy and laser therapy, though the course of treatment on a few of these was less than I would have liked). I can only conclude that brittle scar tissue has built up at this juncture that is causing the continued difficulties.
  18. tumbleweed
    4,067
    687
    Eastern Oregon
    I agree, if you are unable to do it yourself finding a good independent mechanic that knows a little about the Prius would be a good way to go.
  19. tonyk81
    25
    Utah
    I don't have my C yet. That's why I can't jump underneath and look. I was just asking when I was there looking at the cars. For my own info after the complimentary changes since I usually do my own basic work.
  20. tonyk81
    25
    Utah
    Vinnie, did you buy your C at Stephen Wade or another dealer?
