Prius c only getting 43mpg avg
Discussion in 'Prius c Main Forum' started by Poolgod, Nov 3, 2012.
  1. Poolgod
    Poolgod New Member
    16
    I'm a newbie here. I just bought a Prius c 2 model. I love the car but I'm disappointed in the mpg so far. I have driven 1100 miles since I had it. I just put my 3rd tank of gas in. My problem is that I have only gotten 43 mpg on all 3 tanks. I bought the car strictly because I wanted 50 plus. I'm have been driving normal. I keep it in Eco mode. So does my car have something wrong or what. Anybody with some similar issues out there?
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    How about resetting your trip computer A and B.
  3. Poolgod
    Poolgod New Member
    16
    I have reset my b trip every time I filled up. Leave trip A on a running total. The only thing I can think is that I drive to fast. Over half my miles have been interstate or highway. I drive in Louisiana weather. Hoping it gets better after car breaks in more.
  4. JMD
    3,779
    1,282
    I had my car about 6 weeks now. After reading this site I implemented pulse and glide and keep the car light on weight and increased my mileage. I also keep the windows up and AC on low. There is a video on YouTube on hypermiling techniques.try and keep the bar in echo side of he bar if possible. Foot off the gas when cars re topped far ahead. Drive 55-65 on highway for maximum mileage and 35-45 on local. Under 20 MPH use elec mode.
  5. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Please answer the answer the questionnaire. It's not productive for people trying to help to guess or to go back and forth (sometimes w/the OP never responding). We don't know how fast is "to fast". We also don't know things such as your temperatures, tire pressure and how you're using your HVAC system.
  6. Poolgod
    Poolgod New Member
    16
    The answer to the questions. Avg temp here in last 2 weeks. 50-75. Tire pressure-don't know. Everything else. Answer it's a brand new car with 1200 miles now. I have watched the videos and drive like a normal person. Even more careful since I have has this car. I drive at 31 mile trips mostly. 5 miles city driving. 15 miles at 55-60. 10 miles 70-75. I drive as smoothly as possible. I do use my ac when I'm hot and the heater while I'm cold but adjust temps to normal after a few minutes of riding.
  7. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Thanks, but there are still many unanswered questions. Please check your tire pressure, for one. We still don't know how you're driving. If you're trying to accelerate so slowly so that you're in electric, that's generally not a good idea for FE.
    If you're using the heater, you may be causing the engine to run unnecessarily (see Why mileage gets worse in winter | PriusChat). If you're using auto and AC is on, you could be unnecessarily running the AC compressor.
    We also don't know how you're arriving at "43 mpg". Manual calculations? Trip computer? Incorrect manual calculations?
  8. Poolgod
    Poolgod New Member
    16
    Calculations come from trip A and trip B readings and they are the final avg. When I run the heater I do it at a higher temp until it warms the inside of car(usually 5-7 minutes) Afterwards temp is adjusted to around 68. When I use ac I adjust temp to 70 on mid fan. My driving is normal. I don't punch it and I don't grandma it. Just normal. I keep it in Eco mode so it don't actually let me take off fast.
  9. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Doing that can cause the engine to run unnecessarily to provide cabin heat. While the engine is cold, I would NOT use auto, set the heat to high and fan to off when stopped/idling and at low speeds. Only when you need harder acceleration (where the engine must come on anyway) or you're driving above 46 mph (not sure what the cutoff/threshold is on Prius c) should you turn the fan on.
    If you play w/the fan being on/off w/heat on high and a cold engine, you'll see what I'm talking about re: engine running to provide cabin heat.
  10. Poolgod
    Poolgod New Member
    16
    Alright but I haven't used the heat that much. Just a small percentage of my overall driving. In fact I have used more ac than heat. Mostly I have using a mid to low fan after I turn ac off. The thing I have noticed with this car is I do get a least 50 when driving slower or stop and go but my only problem is the overall avg not doing what I expected.
  11. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    The problem is, you're using heat when the engine's cold and still warming up. Engine is inefficient when cold, using even more fuel.
    Why do you expect 50+ mpg? Have you read my link about what the EPA tests consist of and how they're conducted?
    You're going to need to check a whole bunch of things and get back to us. It would really help if you answered the questions instead of this back/forth. We're still missing a lot of info.
  12. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Pretty close... my ICE is forced on when the speed is in excess of a point between 76 and 77 km/h which is around 47-48 mph.
    cwerdna likes this.
  13. Poolgod
    Poolgod New Member
    16
    Alright but I expect it because I read other people's bragging on how their Prius has done some 60 mpg runs so with this I based my final decision to buy the car. I do love the car but I can't even get to the minimum 46 on hwy like I have read about and expected when I bought the car. That is reason for my frustration. You can say I'm jealous of what other people with the same car are getting. I will check my tire pressure and answer any more questions tomorrow some time.
  14. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Why is 46 mpg highway a "minimum"? Did you read about the EPA tests? EPA test results should not be interpreted as a mileage to expect.
    They don't run them on a real road, but rather a dyno (rollers). They don't measure actual fuel usage (but rather derive it from tailpipe emissions). The highest AVERAGE speed of any of the test cycles is 48.4 mph. The highway test and the other higher speed cycle (both ~48 mph) are begun with an already warm engine.
    Please read Your Mileage Will Still Vary and Many Factors Affect MPG.
    Can any Prius c folks chime in an how valid the tips at HSI are for the c? (I have a Gen 2, so I have no HSI bar or anything like that.)
  15. Poolgod
    Poolgod New Member
    16
    I don't care about the tests. I go by real results from real people posting their results. Simple numbers=I have seen 42 mostly on the higher speeds 50-52 on slow speeds mostly. Averages 43mpg by my cars readings. The only thing I can see that I have read that may change my mpg is to check my tire pressure. We will see after that
  16. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    We're all still relative newbies to the model (and unsurprisingly it appears almost all of us are new to the Prius), but the tips on that page (and there's also a similar YouTube video doing the rounds) seem logical and largely appear to hold true. My 2c however is that I've stopped worrying too much about keeping away from the edges of zones as most guides seem to recommend - if my intention is to be in the upper half of the ECO zone, then anywhere in that zone is fine by me.
    I've yet to get a Scanguage and in the c you can't have the HSI and instant MPG shown at the same time, so without that data it's hard to do any more than get a feel. This said, my lifetime mileage of 55.5 is currently in the upper quarter of c's reported on Fuelly and above the overall model average of 51.5, so I'm reasonably happy.
    Toyota Prius C MPG Reports | Fuelly
    I'm still trying to target the impossible though - the Australian standard figures which are 3.7 l/100km (63.6 mpg) urban, 3.8 (61.9) extra urban and 3.9 (60.3) combined - yes, combined is the worst figure. Just 6% of c's on Fuelly are hitting these levels... but hey, you have to aim high.
    Agree with what you're saying though... the OP would be well served to go through Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat to get more informative answers here.
  17. JMD
    3,779
    1,282
    There is one trip I make where I get 38 MPG. It is mostly uphill. When I drive the ice is always on in power mode. My suggestion is now you have figured out how to drive and understand the mileage techniques you should reset your trips a and b and start fresh. I think your damage was done during your learning curve and you are trying to overcome that low stat. Has some of the new trips meet your 50 + mpg criteria? Are you driving with high head on winds? Practice and technique will show improvement.
  18. JMD
    3,779
    1,282
    Check out this video.
    Rob.au likes this.
  19. vtx1800r
    vtx1800r New Member
    25
    This is gonna sound like Sacrilege on here. I drive the car like a regular gas car. I am not easy on the throttle, but don't gun it. I brake as I have always braked, not slamming on them, and coasting to a stop where I see it happening. I check my tires as I always have after each fill up, which is about once a month. I use the heat, I use the A/C in auto mode. I drive mostly rural roads so anywhere from about 40-50 mph for 5.7 miles to and from work. Not the best for getting the absolute most from the car by any means. I still get 47-50 MPG. The only thing I have noticed in milage on my tank is type of gas. If I use ethanol gas, I will take a 3-5 mpg hit in milage for that tank. I try to use non ethanol gas as much as possible (easy with our range on the car). This also keeps the station that sells the gas (local) in business as his prices are a couple of cents more.
    My other car is a 71 Monte Carlo with a 402 big block. I am used to that kind of power from experience. Other then the Prius C sounding like it is working a little harder (cvt), it delivers. I didn't buy it for milage alone. I liked the styling, handling, etunes, easy iphone charge, seats, visiblity and overall drivablity.
    Now that I have been long winded, could you be using ethanol gas?
