Prius C rear license plate bolt rusted
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Hot_Dog, May 27, 2026.
  1. Hot_Dog
    Hot_Dog New Member
    Virginia
    My niece has a 2012 Prius C. One of the rear license plate bolts is rusted and cannot be removed. The bolts are Phillips head M6x1.0mm and about 1-inch long. The steel nuts are apparently spot welded to the inside of the hatch. I tried spraying it multiple times with penetrating oil and using vice grips, but it's rusted solid. Finally, I cutoff the old plate and have the new temporarily attached with one bolt.
    I was thinking of just drilling the head off the rusted bolt and trying to unscrew it from the inside using vice grips. My question: Is the bolt accessible from the inside of the rear hatch after removing the fiber cover?
  2. PriusCamper
    PriusCamper Senior Member
    13,440
    5,426
    Pacific Northwest, USA
  3. Hot_Dog
    Hot_Dog New Member
    Virginia
    My original thoughts were to drill and use a bolt extractor, but the bolt is so solidly frozen I'm worried that it might cause the extractor to snap. My plan B was to drill the bolt and cut new threads with a tap. Maybe go from M6 to 1/4-20 if I'm unable to retap to the original thread.
    On her car, the nut appears to be spot welded to the hatch lid. It's not clear to me why Toyota use such a long bolt. At this point, I also don't know if it's rusted just inside the nut or also rusted beyond the nut inside the hatch. I thought that I would be able to remove it by unscrewing from the inside of the hatch, but that might not work either.
  4. PriusCamper
    13,440
    5,426
    If this were my job, I'd probably find a screw head that matched the other one and use liquid metal epoxy to hold the head and plate in place. It's not worth the hassle to do more than that.
  5. Leadfoot J. McCoalroller
    8,280
    7,791
    Pennsylvania
    2018 Prius c
    I've fought many rusty bolts- don't forget the power of time. Hit it with penetrating oil, clamp it with vise-grips and use a driver at the same time. Try tightening as well as loosening. Even if you can only move it a couple of degrees, do it. Then give it a day and repeat.
    Sometimes you can get some action by putting the driver in the screw head and giving the back of the screwdriver a sharp strike with a hammer, just to shock the threads a bit.
    PriusCamper likes this.
  6. ChapmanF
    18,999
    Lisle and Thexton sell swell tools for that kind of thing, if you have access to an air hammer:
    lisle thexton fastener removal -plastic at DuckDuckGo
    The hammer just gently (you feather the trigger) but rapidly bops straight down on the tool, while you easily turn it from the side (with a wrench on the Lisle, or the Thexton's own little handle). The air power is not used for twisting like an impact wrench, so you aren't going to break the head off or strip it. This thing has worked for me like magic.
    If the search above comes up with a 9 minute 38 second youtube video, don't watch it. In 9 minutes and 38 seconds he actually never shows the tool in use. It takes him 5 minutes to get around to showing the tool at all. My neighbors don't often hear me yelling "edit your effing video" at my phone, but they did just now.
    Of course the tool is intended for when the head is still there. If it's already cut off, this tool won't really be the thing.
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    The professional method:
    Drill out the center of the Phillips screw with a 1/8 drill bit. Use cutting oil or any other lubricant.
    Progressively increase the drill size until reaching the number 4 drill, which is the M6x1.0 root diameter.
    Use an awl and a pair of needle nosed pliers to remove the remaining thread which is like a spiral helix wound wire.
    Retap the hole with an M6x1.0 tap.
    The alternative would be to drill out the bolt and hole for an M6x1.0 rivet nut.
    #7 Georgina Rudkus, May 28, 2026
    Albert Barbuto likes this.
  8. Hot_Dog
    Hot_Dog New Member
    Virginia
    Thanks for all the helpful suggestions. If the car were here, I'd probably keep hitting it with penetrating oil as Leadfoot suggested. I know that penetrating oil takes time to do its job. Problem is I live in northern VA and she lives in Wilmington, NC. I was visiting her for the Memorial Day weekend when this all came up. Next time I see her will be over the July 4th weekend. I'll probably use the method that Georgina suggested. I don't think there's any other alternative method that will work. It's half assed the way Toyota did this.
  9. Hot_Dog
    Hot_Dog New Member
    Virginia
    Reply to ChapmanF's post: Interesting. Never seen one of these tools before. It's similar to a manual impact driver, which I've used before. They work like magic. Unfortunately, the Phillips head got rounded off when she and her boyfriend tried to remove the screw.
  10. ChapmanF
    18,999
    Your first post mentioned the plate had been cut off. Is the stuck bolt head still there (even with the cross recess rounded out)? Or did it get cut off as well, leaving only a bolt shank ending close to the surface?
    If there is a head left at all, I would probably still try the Lisle or Thexton thingy, just using a straight bit, and Dremeling a straight slot into the head for it. The magic of the tool is the straight bopping on the axis of the screw, not how much torque you can put on to turn it. What happens while it's being air-bopped is you can turn it relatively easily using the handle/wrench on the side of the tool.
    That makes it a little bit different from the hand impact tools you bop with a hammer. Those contain a cam so that some of your bop is turned into torque. In the air version, all of the turning torque comes just from your hand on the handle/wrench, and all of the air bopping just shakes the screw on-axis.
    If the head got cut off, I might at least pop off the inside trim and see what I could see. If there is a way to chomp some Vise-Grips down on the screw projecting inside, I might try to kind of replicate the air tool by doing that, and applying some torque with the Vise-Grips, while bopping on the cut-off outside end of the screw with a narrow punch chucked into the air hammer. (Again presuming availability of an air hammer.)
    Getting the old screw cleanly out of the welded nut would still be my first preference, before I would go to a solution like Georgina's. Drilling out to the root diameter and retapping is great when the drilling is perfectly centered and everything goes right, and maybe things go perfectly for other people more often than they do for me....
  11. Hot_Dog
    Hot_Dog New Member
    Virginia
    Reply to ChapmanF's post: Yeah, I was able to remove one bolt and snipe off the old aluminum license plate at the other bolt. The head is still on at the frozen bolt, but the Phillips slot is rounded off. I thought of slotting the head of the frozen bolt, but I don't think that would get me anywhere. I can grasp the head with vice grips, but it's frozen solid. As of now, I think the best solution is just to drill it out and retap the hole.
  12. Leadfoot J. McCoalroller
    8,280
    7,791
    Pennsylvania
    2018 Prius c
    Ah, yeah. Deadlines and rustbusting aren't great mates.
    If you do decide to drill the thing out, you may want to do a prep step of using a dremel or the like to grind a flat face onto the screw, such that you can hit it with a center punch so that you have a nice clean landing for the first drill bit.
    (I hate the thought of a drill skittering out of a screw head and then scratching the paint.)
    Good luck!
  13. Hot_Dog
    Hot_Dog New Member
    Virginia
    Thanks for the helpful suggestion.
  14. Mendel Leisk
    42,315
    You should check the spare tire hold-down bolt too, might also be rust-seized.
  15. Hot_Dog
    Hot_Dog New Member
    Virginia
    Thank you, sir. Will do that.
  16. Albert Barbuto
    Albert Barbuto Active Member
    116
    108
    Northeast USA
    When I purchased my Prius, one of the license plate bolts was snapped off, and rusted. I drilled and retapped the threads, as this was the least time consuming method for me.
    Hot_Dog and Georgina Rudkus like this.
