Prius C Traction Battery please help i am out of ideas
Discussion in 'Prius c Main Forum' started by Javierz0509, Dec 18, 2017.
  1. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    We've already seen reports here of a few Prius C batteries failing. The first one I recall was also a delivery driver from like Az or southern California (both hot like Miami) who had a lot of miles and was well past the 150k mile warranty. I believe he found and installed a used pack from another 2013.
  2. fotomoto
    5,638
    3,813
    So. Texas
    This is first evidence I've seen of an auto parts store reader actually seeing a hybrid specific code. Hopefully this good news for hybrid owners if they are using more capable code readers now.
    jerrymildred and Prodigyplace like this.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    12.5 is NOT a good charging voltage.
    Since the resting voltage of a fully charged AGM runs around 12.8, that indicates a slight discharge.
    If that reading was taken when the car was actually ON and ready to drive......then you have a charging system problem.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Toyo Kings Used Auto Parts in Opa Locka (about 5 miles from you?) shows as having a 2014 Prius C battery available. 29k miles.
    1-305-688-6200 No price listed but may be worth checking out.
  5. Prodigyplace
    12,558
    11,775
    Central Virginia
    Thanks.
    I meant to tag you, but could not remember your username. :(
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    Nope. 8 years or 100,000 miles.
    Prodigyplace likes this.
  7. bisco
    51,908
    how are the mpg's?
  8. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    High 55 to 65mpg
    And here are the voltage of the individual module.
  9. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    Thank you I will call tomorrow and ask them how much is that battery
  10. fotomoto
    5,638
    3,813
    So. Texas
    Your voltages aren't horrible but wait for a professional opinion on that. You might also look into grid charging and see if that could be right for you and your situation.
    #30 fotomoto, Dec 19, 2017
    jerrymildred likes this.
  11. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    Well since I have the battery out I am cleaning out the terminals or whatever these things are call but they seem really dirty. Guys I thank you for the advice and I appreciate it more if anything
  12. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Cleaning them is a good step. Although I use muriatic acid, the green Scotchbrite pads can sometimes work miracles, and are much easier to dispose of....... Loosening and re-torquing all the fasteners won't hurt either. I would also disconnect and inspect all the electrical plugs. Just be sure to fully "click" them back together afterward.
  13. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    Here is what they look like now.
    ztanos and Raytheeagle like this.
  14. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Looking better!! Don't forget, recommended torque value for those module fasteners is 48 INCH pounds. (3 ft lbs)
  15. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    By the way those terminal plates are the ones that have the wires that go into the battery computer on the side, those plates were the most dirty.
    #35 Javierz0509, Dec 19, 2017
  16. jerrymildred
    11,517
    14,151
    Tampa, FL
    Good job! Those ones you just mentioned are the ones I think cause some people to replace batteries that aren't necessarily bad.
    #36 jerrymildred, Dec 20, 2017
  17. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    I hope that's my case, well I put everything back together and the car turns on fine no error, but since the error message comes on randomly I guess now I have to drive it and see.
  18. Prodigyplace
    12,558
    11,775
    Central Virginia
    Did you torque the connections to the proper spec? Some people who just guessed at the torque have had issues later.
  19. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    i did yeah @TMR-JWAP gave the torque spec.
  20. ericbecky
    ericbecky Hybrid Battery Hero
    4,438
    3,306
    Madison, Wisconsin
    While you are in there check for corrosion on the pins of the voltage sensing wire connector at the ECU.
    As well as at the crimp portions of the ring terminals.
