Prius C Traction Battery please help i am out of ideas
Discussion in 'Prius c Main Forum' started by Javierz0509, Dec 18, 2017.
  1. SpaceCityHybrids
    38
    52
    Houston
    A lot of newer OBD2 scanners will pull the hybrid module codes. I have a $10 unit with a cord that does just that.
  2. SpaceCityHybrids
    38
    52
    Houston
    Ditto on Scotchbrit pads.
    Alternatively you can find some nicely cleaned ones on eBay.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    Cool! Which one is it?
    Raytheeagle likes this.
  4. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    I was specifically referring to the readers used by auto parts stores who provide free code reading services. Literally thousands of threads here over the years from folks who either don't want to pay, need immediate readings, or just don't want the hassle of obtaining their own readers. So, they typically only have two options: paying big bucks at a dealership ($150+) or free at the auto parts store. Guess which one they choose? ;) . :)
    jerrymildred likes this.
  5. SpaceCityHybrids
    38
    52
    Houston
    Oh I know, I was just pointing out some of the cheap units these auto parts stores use now have the ability to pull some of the hybrid codes.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,438
    3,306
    Madison, Wisconsin
    Once you have the codes and plan to do the work yourself getting your own reader is going to make your life easier.
    fotomoto and jerrymildred like this.
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I know this is right.. it just never made sense to me.
    48 inches = 4 ft, but 45 inch lbs = 3 ft lbs...
    #47 ztanos, Dec 20, 2017
  8. Prodigyplace
    12,558
    11,775
    Central Virginia
    According to on online calculator 45 inch lbs = 3.75 ft lbs. That makes a little more sense. I guess you rounded down instead of rounding up.
  9. Mendel Leisk
    41,434
    Just divide inch/pounds by 12 to get foot/pounds.
    Inch/pounds are basically a force applied one inch from fulcrum, vs 12" for foot/pounds.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Yikes......I failed math....Wait...you mean a foot is 12 inches and not 16? Geez....48 inch pounds IS 4 ft lbs. (not 3) . Sure am glad I use an inch pound torque wrench
    I'll learn one of these days. I think its a mental thing for me, as the last part (pound) seems to trigger 16 in my head. Isn't the first time I've done this converting in-lb into ft-lb.
    #50 TMR-JWAP, Dec 20, 2017
    Prodigyplace and Raytheeagle like this.
  11. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Happens to the best of us... like how I meant to write 48 and wrote 45. :D
  12. Mendel Leisk
    41,434
    Best to get a 1/4" drive torque wrench, deal with the values in inch/pounds. I'd hazard the torque is similar to what you could do holding a 3/8" ratchet one handed, just covering the center with your hand and turning firmly.
    jerrymildred and Prodigyplace like this.
  13. jerrymildred
    11,517
    14,151
    Tampa, FL
    Agreed. It's easier to be accurate with the higher resolution of inch/pounds in those low torque ranges. Otherwise, it's like weighing an envelope with a truck scale. (An exaggeration to make the point. :D)
    Mendel Leisk and Raytheeagle like this.
  14. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    They still make envelopes :p?
  15. jerrymildred
    11,517
    14,151
    Tampa, FL
    We just sent out several thousand of them with our mission's Christmas letter.
  16. Mendel Leisk
    41,434
    Yeah I remember a Sears salesman saying you want to use a torque wrench nearer the middle of it's range; the ends are less accurate. I guess if I ever got into battery rebuild I'd shell-out for a 1/4" drive torque wrench. Right now I've only got 3/8" and 1/2". The 3/8" I just got a few years back, the 1/2" I've had for decades.
    Our dentist(s) have these itty-bitty torque wrenches, for torquing implant pins. They're very expensive too, they've mentioned.
  17. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    and it failed again, i got the check hybrid system message, really in a bucket here now.
  18. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Back in the days when I was in the New-clear power program, if I'm remembering correctly, procedure (and Quality Control Inspectors) required all torque values to fall between 1/4 and 7/8 of the full scale of the torque wrench being used.
    jerrymildred and Mendel Leisk like this.
  19. Mendel Leisk
    41,434
    Scary to think, that a mushroom cloud on the horizon is just a wonky torque wrench away...
    jerrymildred and Raytheeagle like this.
  20. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Were you able to
    Is it still P0A80? Were you able to contact that recycling yard?
