Prius C Won’t Start After 1 Month
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ClarkDelmar14, Mar 14, 2021.
  1. Leadfoot J. McCoalroller
    8,092
    7,573
    Pennsylvania
    2018 Prius c
    Clean the hybrid fan down at the car wash vacuum stall. There are how-to videos on youtube if you aren't already familiar with the process.
    I'd get another opinion from an indy garage- someplace that doesn't sell cars.
    If you really do need a head gasket, it's probably going to be cheapest to pay an indy garage to install a good used engine. I would let that shop become heavily involved in sourcing that engine, because otherwise they will be hesitant to take responsibility for the results should there be any problem later.
    ClarkDelmar14 likes this.
  2. ClarkDelmar14
    ClarkDelmar14 New Member
    Leesburg Va
    2014 Prius c
    Is there any recall for this car?
  3. Leadfoot J. McCoalroller
    8,092
    7,573
    Pennsylvania
    2018 Prius c
    I wouldn't know for sure. You can enter your VIN on Toyota's website. There is a service program (not a recall) for rain leaks in the taillights on the 2018 model.
    Overall these cars are the tightest things Toyota makes- so I'm pretty surprised to hear about a head gasket leak. That's why I'm suggesting an indy shop who doesn't just want you to trade it in.
  4. topshot
    topshot Member
    145
    57
    Midwest
    2015 Prius c
    The multiple misfires combined with potential low coolant could be significant. Not sure why bisco was dogging the engine design as these 1.5 L are quite robust, but if you have been letting it run hot for a while that could eventually cause gasket failure. How did you check the coolant level/condition? I'd check the cylinder compression. That's a quick and easy test for most gasket issues or check for oil in coolant and bleed any air out of the system. If you have good compression on all cylinders and coolant is good, I highly doubt it's a gasket so misfires are from something else.
    It appears you do have a bad traction battery - one since it wouldn't jump start (it's the traction battery that starts the engine while the "jump" is to recover from a bad 12V to power the computers) and, two, block #1 has much lower voltage than the others. Clean the vent under drivers side rear seat!
  5. Leadfoot J. McCoalroller
    8,092
    7,573
    Pennsylvania
    2018 Prius c
    How old is the fuel in this car?
    Stale fuel can contribute considerably to misfires.
    Any more details on the coolant level and history?
    davecook89t likes this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    IF......it turns out that your engine AND the hybrid battery have BOTH gone bad,
    I think it would be a MUCH better move to trade it in on a newer model.
    Trying to get things done "on the cheap" often turns out to be MORE expensive in the long run.
    Then.....if you are on a really tight budget, a hybrid might not be the best bang for your buck either.
    A base model Corolla (or similar) might be a better choice.
  7. ClarkDelmar14
    Leesburg Va
    2014 Prius c
    I think I’ll trade in for Corolla. Thanks anyway
