Prius C Working Progress
Discussion in 'Prius c Audio and Electronics' started by fun420fun, Mar 12, 2013.
  1. fun420fun
    fun420fun Junior Member
    Alpine SPR-60C
    Alpine SPR-60
    Alpine PDX-V9
    Audio Control LC7i
    Boston G2 12"
    Back-Up Cam
    Dynamat Xtreme 36 sq.ft.
    Center Dome Light + LED
    LED Floor lights
    Navi Speed Lock Bypass
    amp.jpg batt.jpg batt2.jpg batt3.jpg batt4.jpg dome.jpg dome2.jpg dome3.jpg fl_door.jpg fl_door2.jpg fl_door3.jpg fl_door4.jpg fl_door5.jpg fr_door.jpg fr_door2.jpg fr_door3.jpg fr_door4.jpg fr_door5.jpg g2_12.jpg gps_lock.jpg gps_lock2.jpg lc7i.jpg lc7i2.jpg led_dome.jpg led_dome2.jpg led_dome3.jpg led_dome4.jpg led_floor.jpg led_floor2.jpg led&cam.jpg led&cam2.jpg radio.jpg rc1.jpg rc2.jpg rc3.jpg rc4.jpg roof.jpg rr_door.jpg rr_door2.jpg rr_door3.jpg swire.jpg swire2.jpg swire3.jpg switches.jpg
  2. norahs
    norahs Junior Member
    52
    Bay Area, CA
    nice!! can i ask what backup camera you got? i like how it doesn't take away one of the license plate lights.
    was the navi lock override an easy install? did you buy from priuschat?
  3. fun420fun
    Thanks! the cam is DP VIDEO DBC466 Vehicle Rear View Camera i got from frys. its a nice fit, no cutting or drilling. the navi lock i made it with CPROAUDIO instructions. Anyone interested in how to bypass the factory navigation speed lock? | PriusChat. it was fairly easy to install it took a little time.
  4. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    I'm try to figure out how do you hold the backup camera? Close pic please?
    I like the Center Dome Light + LED and the LED Floor lights also. how do you do it?
  5. col127
    col127 Member
    345
    Illinois
  6. col127
    col127 Member
    345
    Illinois
    amazing, amazing work. love the centre dome light + LED floor lights. how hard was that to do? how did you remove the headliner?
    i was also thinking of sound deadening the car - but i'm not very handy. how'd you approach doing it? looks like you were pretty light on the doors.
  7. fun420fun
    i used double sided tape, i also flipped and bent the bracket a bit.
    the center dome light was a pain. removing the headliner was a puzzle. after removing all the oh-$hit bars and all the panels, headliner was stuck in the car i had to bend and telt to remove it out of the car. the floor leds were easy. the front led under the driver has +/- connected to the dome, the other end is connected to the other three leds which are basically T'ed.
    the 36 sq.ft. Dynamat weighs about 20lbs. i did the inside and the back side of the doors, it doesent look like much in the pics. i also Dynamat all the plastic panels in the car. it works perfect keeping vibration outs and some road noise. i was thinking of using some of the spray, but no need.
  8. Priusxrs
    Priusxrs Junior Member
    61
    Pa
    How hard was the lc7 to install/hook up. I have the lc6i that im planning on installing once i get 2 nice days. Day 1 coilovers day 2 will be electrical
    SGH-T889 ? 2
  9. fun420fun
    lc7i was simple to install. If you have the six speaker, it was hard finding the front speaker channel. its from the tweeters n they have 4 wires. i wish i had tapped in from behind the radio. i did not use the line in channel 3 but I did connect the RCA out so that the sub gets its own channel. its better to use lc7i because of AccuBass. Most factory stereos drop the base frequency when you raise the volume. AccuBass keeps your base frequency going. just make note that things always dont go how u want it to go.
  10. 2015Prius2
    2015Prius2 Member
    150
    67
    Clean install, I like how you took the time to run the speaker wire through the molex plug, I did the same.
  11. col127
    col127 Member
    345
    Illinois
    When you say the Floor LEDs were connected to the dome, do you mean the wire ran up to the top of the car where the dome lights are? How is it connected to the dome? Sorry if that's a dumb question. I'd love to do those led lights :) do they only turn on when the doors open and close? That's exactly what i want to do.
    Also, where did you get the second dome light from?
  12. fun420fun
    Thank you. Yes, I taped the wires from the domelight on the roof and run wires down to the floor. The leds turn on and off just like dome light. I did put a separate switch for "dome(on)-all(off)-all(on)". The 2ed dome light i got from junk yard.
  13. fun420fun
  14. Hartish Khoobarry
    Hartish Khoobarry Junior Member
    49
    Mauritius
    2014 Prius c
    Hi..where did pass all the RCA Wires??
    Did you pass then in a straight line from front to back?
