Prius CAN Monitor and data logger for Windows PC
Discussion in 'Gen 2 Prius Technical Discussion' started by ken1784, Oct 23, 2006.
  1. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Just FYI,
    HV battery SOC: CAN-ID 0x3CB byte#2 and #3
    HV battery voltage: CAN-ID 0x03B byte#2 and #3
    Our bible is Attila's spread sheet...
    http://vassfamily.net/ToyotaPrius/CAN/PriusCodes.xls
    Ken@Japan
  2. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    dup
    Ken@Japan
  3. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    dup2
    Ken@Japan
  4. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    dup3: slow response from PriusChat site...
    Ken@Japan
  5. Flying White Dutchman
    4,376
    313
    google is my friend;) so already have seen attila's site:)
    thx anyway
    really exited for next weekend when i hope i got the adapter!
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Oh, that makes sense now. Was on the phone while typing, must have become confused
    Actually there is a comma, not a decimal, in that figure. $38,000 Cdn is about 25000 Euros
    Only an independantly wealthy person, or a business, can afford one, let alone four of them
  7. Flying White Dutchman
    4,376
    313
    i have the adapter ( elmscan 5 usb )
    got the usb version so its faster!
    already connected it and can communicate is really simple and easy
    but thats the standers things like ice rpm's and temp
    now i have to look into the prius specific info.
  8. Flying White Dutchman
    4,376
    313
    whit pcmscan that i am using i can only send hex codes or bitmasks ( whatever that means )
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I believe Elmscan 5 USB uses 9600 or 38400 bps.
    The PCM communicates 115200 bps with the CAN232.
    Ken@Japan
  10. Flying White Dutchman
    4,376
    313
    your correct
    i got it working with pcmscan
    but when i use a different program special for the elmscan i can set the speed to 500000 bps
    because the usb version of the elkmscan can get a max off 500kpbs
    only problem is that pcmscan gives me a range of pid's ( sensor readings )
    that only are the industrial standards for engine rpm and temp. etc etc.
    only its not showing the prius special HV battery voltage info .......
    already used windows hyper terminal and got a successful connection but then i got HEX codes that i can not translate to something useful
  11. Flying White Dutchman
    4,376
    313
    when i go into terminal mode and send something to the canbus
    then i get the following
    send : 03CB ( battery )
    and get : 7F 03 12
    i translate this to decimals and get
    7f = 127
    03 = 11
    12 = 18
    send : 3B ( em current)
    and get : 7F 3B 12
    7f = 127
    3B = 59
    12 = 18
  12. imwoody36
    imwoody36 the prius parts guy
    143
    116
    southern Indiana
    Hi All,
    Please somebody contact me off list, I would like to get a copy of the PC logging software. Ken?
    thanks so much in advance!
    Steve.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Something isn't right, the passive mode is probably buffer overrun. I'm leaving tomorrow on a business trip, will look into this when I get back next week
  14. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hi Steve,
    I just sent you the software.
    Sorry for my late response.
    Ken@Japan
  15. Flying White Dutchman
    4,376
    313
    like to get the software to
    maybe someone is in contact with the TIM guy
    that made it elmscan workable!
  16. poffy74
    poffy74 New Member
    36
    N. Grafton Ma
    Sometimes reading threads I get confused. :frusty:
    What is the bottom line here? What and where is the best solution for the best price. I'm not looking to reinvent the wheel, but would like to improve what is already invented.
    What ever happened to the elm solution. Reason I ask is they are cheap on ebay. Any ever use the ones from ebay and the software they come with?
    Also, do any of these solutions let you register TPMS sensors? or is all this just strictly read-only?
    If I can figure out what to get, I'll write up a full tutorial on what to do for others.
    steve
  17. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hi imwoody36,
    Are you reading PM?
    I sent you the software by email, but it was rejected by some reason, maybe a spam. :confused:
    Please send me PM again with your email address.
    If you would like to get the software, please send me PM with your email address.
    We don't know the CAN-ID for the TPMS sensors.
    If you know that, please let us know.
    Ken@Japan
  18. Flying White Dutchman
    4,376
    313
    i got the software from ken today
    and started the program
    can readout gas pedal state but thats about it right now
    going to have a look wy i am not seeing brakepadel and battery voltage en soc because thats what for me its all about!!:cool:
  19. imwoody36
    143
    116
    southern Indiana
    Ken, my direct email is
    steve at autobeyours.com
    You know to substitute @ for at
    I have asked my provider to allow email from you..we shall see.
    Apologies to everyone for public post about software,,I promise to make it up to you with a good contribution to the cause.
  20. Flying White Dutchman
    4,376
    313
    i hope it also
    the elmscan is also the device i am using
    i am going to try this tomorrow ( when i have the time ) and send to the elmscan
    for gas gauge, coolant & other misc status (LOW speed)
    ATCF500
    ATCMF00
    ATCMF00
    traction battery status & MPH
    ATCF300
    ATCMF00
    ATCMF00
    ATCMF00"
    traction battery current (high speed)
    ATCF03B
    ATCMFFF
    ATCMFFF
    ATCMFFF
    filter for accelerator pedal (high speed)
    ATCF244
    ATCMFFF
    ATCMFFF
    ATCMFFF
    filter for brake pedal (high speed)
    ATCF030
    ATCMFFF
    ATCMFFF
    ATCMFFF
