Prius canbus message's
Discussion in 'Gen 2 Prius Technical Discussion' started by Flying White Dutchman, Mar 16, 2008.
  1. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Attila's spreadsheet, row 85 and below, explains these.
    Ken@Japan
  2. Flying White Dutchman
    4,376
    313
    damm:mad: i simply cant find the time to get further with the project
    something always comes in between
  3. Flying White Dutchman
    4,376
    313
    in my quest to get torq app to control BMS+
    i just noticed i never got the anwser in this topic about what 7f is
    its the SOC you need to devide it 0,5 so 127 = 63,5 soc
  4. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    7E8, 7EA & 7EB - responses from ECU 7E0, 7E2 & 7E3 respectively
    03 - 3 bytes data
    7F - Negative Response Service Identifier
    03 - Request Service Identifier
    12 - subFunctionNotSupported-InvalidFormat
    This response code indicates that the requested action will not be taken because the server (ECU) does not support the arguments of the request message or the format of the argument bytes do not match the prescribed format for the specified service.
    Mode $03 is to request for emission-related DTC but if you add $CB to it, it becomes an invalid format that the ECU does not support. If you just send 03 without any argument, you 'll get a positive response even if there are no DTC.
    03CB in Attila's excel sheet is a passive msg. as pointed out by Bob64. They are always on the CAN bus and you can read them even if you 're not sending any command. I believe Scangauge also doesn't send out 03C3, it just uses RXF to filter out the 03CB msg.
    AFAIK, Torque does not have AT MA (Monitor All) mode. You need to write your own program to tell ELM327 what msg. to filter and how to display them, e.g. PriiDash.
    Vincent
  5. Flying White Dutchman
    4,376
    313
    Does the command button of torqapp SOP not do this
    It supports raw data send
    ATSH works
    -Htc apatalk
