Prius Check EMV
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by radi, Jun 7, 2019.
  1. radi
    radi New Member
    Frankfurt am Main
    Hello,
    i got those values in the diagnostic mode.
    01 DC 190 17 2
    01 DS 190 38 D
    01 DB 190 2c f
    EMV Chek
    What is that exactly?
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    It’s nothing that can help you with anything. I’m guessing you got the codes from the MFD?
    SFO likes this.
  3. radi
    radi New Member
    Frankfurt am Main
    yes but how to analyse this error, what it is refer to?
  4. Skibob
    2,912
    1,496
    Northern California
    Who told you those codes were error codes? I believe they are codes for the entertainment system, not error codes. Do you have warning lights on?
  5. Elektroingenieur
    2,515
    3,253
    Three Touring
    As @Skibob kindly points out, these are diagnostic trouble codes (DTCs) for the audio or navigation system. The Repair Manual (more info) explains how to decode them.
    Logical address: 01 (Communication control)
    DTC: DC (Failure in transmission)
    Sub code: 190 (Radio receiver assy)
    Connection check number: 17
    Occurrences: 2
    “DS” isn’t a valid code; it should be a hexadecimal number. I’m assuming this was really D5.
    DTC: D5 (Absence of registration unit)
    Connection check number: 38
    Occurrences: D (13)
    DTC: DB (Mode status error)
    Connection check number: 2C
    Occurrences: F (16)
    If these are codes from the EMV (multi-display) page, they indicate a possible communication problem between the multi-display and the radio receiver assembly. The Repair Manual suggests to check the power source circuit for the radio receiver assembly; to check the AVC-LAN circuit between the multi-display and the radio receiver assembly; and if no trouble is found with either circuit, to replace the radio receiver assembly.
    Obviously, those diagnostic steps would be useful only for a problem with the audio or navigation systems. For problems with other systems on the car, you’ll need to use a Toyota Techstream diagnostic system or equivalent, connected to the DLC3 (OBD II) connector, to check for DTCs.
    jerrymildred likes this.
