Prius check hybrid system warning after going over bump on highway
Discussion in 'Gen 3 Prius Main Forum' started by Rishi999, Aug 28, 2019.
  1. Rishi999
    Rishi999 New Member
    Trinidad
    I was driving on the highway at around 130 km/h. Went over two areas where the road was bumpy/elevated. Heard when stuff at the trunk area made noise as it was probably lifted then dropped. About a minute after, the check hybrid system warning message came up and the car started decelerating on it's own and I pulled over and it came to a stop. Now, when I start the vehicle, the ready sign comes on, but the engine does not. If I try switching to drive or reverse, the screen changes to an error message saying to place in park. the car moves in the direction of the gear, but very sluggish and also bucks. If I start the car and do nothing, the HV battery shows full level but decreases rapidly to 1 bar in less than a minute then a constant beep is heard and screen goes into error. Also now the power steering light comes on. So far the engine hasn't turned on and cannot charge the HV battery. The only error code that comes up is P3000 (cant get any subcodes). No error codes for engine or anything else. Was wondering if something could have became loose or wire tear/disconnected when I hit the bump as the car was working flawlessly before. I've also checked the service plug which is correctly intact.
    2005with259k likes this.
  2. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Try disconnecting the 12V battery for a few seconds, then reconnect it to automatically reset a few conditions. If you are lucky, it will not be necessary to expose the HV battery and begin looking for broken bus bars or other connectors.
  3. Rishi999
    Rishi999 New Member
    Trinidad
    Thanks for the reply, however I have tried this to no avail. Engine still does not come on and same issues arise
  4. bettergolf
    bettergolf Active Member
    331
    291
    Sanford NC
    Based on your description of how this happened, I would unplug and reconnect every connector that is associated with the high voltage hybrid battery and hybrid system, both under the hood and at the hybrid battery location. It sounds like the hybrid battery is not plugged in somewhere and the car will not run even on the gas engine if the hybrid battery is dead or not connected.
  5. cnc97
    cnc97 Senior Member
    1,409
    1,520
    38
    Evansville, IN
    I wonder if the bump is unrelated to the condition, just coincidental. I wonder if the inverter has failed. You start the car and it is ok until you shift into gear then it quits. I bet there are more codes, your tool just can’t read them.
    Tim Jones and Mendel Leisk like this.
  6. Rishi999
    Rishi999 New Member
    Trinidad
    If I start the car and also wait about 1 minute or less without doing anything, it still goes into error. Can this be a symptom of failed inverter also?
  7. Rishi999
    Rishi999 New Member
    Trinidad
    I was told that it's possible that it can be a bad HV battery ECU. How likely is this?
  8. cnc97
    cnc97 Senior Member
    1,409
    1,520
    38
    Evansville, IN
    It could be either one. The key is getting it to a hybrid specialist for a once over. That will be the key.
  9. Rishi999
    Rishi999 New Member
    Trinidad
    Tried the new hv battery ecu and same problem. I was told that there is power from the inverter but mg1 isn't starting.
    Are there any fuse or sensors that will prevent mg1 from turning? Also there are no codes being logged so is it possible that it can be a mechanical issue with mg1?
  10. 2005with259k
    2005with259k Junior Member
    Michigan
    My Gen 2 Prius hit a HUGE pothole I did not even see. I had no problems before that. My Hybrid Triangle of death light comes on now if I hit some small bumps too. I think when we hit big bumps like that all the objects, including batteries, are temporarily lifted into that free fall state. Its just milliseconds but its enough that when the car slams down in knocks sensitive connections loose. I know this from electronics experience. I am trying to go through my trunk to my battery to see if anything is loose, but I do not know what to disconnect to protect myself from becoming fried
  11. Johnny Cakes
    Johnny Cakes Senior Member
    939
    713
    Virginia, USA
    Sorry for your hassles! You may want to ask a Moderator to move this post to the GEN2 forum for more specific replies.
    Grit likes this.
  12. Lepidopteress
    Lepidopteress New Member
    Albuquerque
    2002 Prius
    Similar experience---driving 10 miles into a wilderness area on washboard dirt road and back out 2 days ago. No problems, but I kept thinking that I would be amazed if something didn't come loose. Made it home fine---40.5 mpg. Next morning I start to leave my house and something sounded and felt odd--no oomph, then the warning light and hybrid system light came on and car basically limped to the side of the road. It has been 10 years since I replaced my original battery (original owner), so figured it might be that, but it also reminded me of when the the code indicated I was having an inverter problem.. turned out to actually be just the inverter cooling which does not show up as a separate code for gen. 1. Anyway, trying to decide to day how to proceed and after talking to my mechanic at the dealership, decide to borrow a diagnostic code reader. Nothing comes up, though the warning lights still are on, so we reset the codes at the aux. battery and tried again. Still nothing, and the warning lights don't come back on. After a very short test drive around the block, everything seems back to normal. All I can think is that Priscilla Prius was offended at having been taken on that back country adventure and went on strike for a day. I think I will still take her in and have connections all checked though. The problem coinciding with the rough road abuse and still quite decent mileage kind of rules out battery. Still could be inverter/inverter cooling though I guess.
Loading...
