Prius Chief Engineer Confirms Hybrid Yaris
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Mar 25, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    With a 1 litre 3 cylinder, 70 mpg minimum
  2. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    depends on where you drive it... i think the biggest issue is that the best mpg wont be much different (one you get from cruising at 45 mph), big difference will be in the city and real life driving conditions where it could get 20-30% better consumption than Prius... problem is that there is no way for people to realize that until they drive it, because govt tests wont reflect those improvements.
    and of course, some smart euro journalists will drive it 85 mph on highway and conclude that 520d or E220CDI gets better mileage
  3. spwolf
    3,156
    440
    Eastern Europe
    Yaris has decent boot -you can fit stroller in there. Perception problem is that there was an shelf there that made seats fold perfectly flat and under it you had rest of the trunk... in facelift they removed that shelf, and it makes it less functional but pereceptionally it shows a "lot bigger trunk".
    Next gen Yaris is rumoured to be based on iQ tech, which means more space in same package, and Yaris is already packaging champion. In fact, Toyota suggested that there will be 7 seater based on Yaris which tells you how much space they will be saving based on iQ technology.
  4. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Uhm, the extra small size is kinda the whole point. If you want a family size hybrid, go with the Prius or the new Lexus hybrid. If you want a small hybrid, Honda already has the Civic Hybrid and Insight, no reason to fight the two of them. So this comes in under that for the truly fuel efficient-minded consumers. No one car will work for everybody.
    They just really need to make an efficient minivan hybrid, even if they have to do away with the flat cargo floor in the back for the battery pack (apparently that's one of their hangups, Toyota thinks consumers won't buy a hybrid minivan if the back seat can't be taken out or folded flat and a loading dock be available there).
  5. nerfer
    2,507
    237
    28
    Danny ventured the first guess in the story article (home page, or follow link on first post). He guessed 65 mpg as being a possibility
  6. Tideland Prius
    16,490
    Yes but with the current one, where are you going to put the battery? You'll need a larger boot to accomdate the battery. I'm not saying it has to be the size of a Prius (which, not coincidentally is the size of a Corolla on the outside). Seeing the iQ, I am confident Toyota can create a good package.
    And they do have two minivan hybrids - Alphard Hybrid and Estima Hybrid (which can be loaded up with alll the Lexus features like ACC, LKA, IPA, G-Book, AFS, HID, Power Tailgate, backup camera, SideView cameras, leather/wood steering wheel, ottoman, dual power moonroofs etc etc.
    It may not have shown up stateside. I do remember this thing that you can flip from the cargo area to cover up the gap between the seats and the cargo floor plus use the plastic side rather than the carpet.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I'm in no rush. Holding out for a HSD Fit. ;)
  8. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    This is where the screwed-up patent system will be a problem.
    The point of the patent system was to have designs published openly, so they could be used for advancing the state of the art, in return for rewarding the inventor for doing so. Instead it's being used as a way to prevent designs being used, either by restricting them to their original inventor or to take them off the market entirely (Cobasys NiMH patent). You can't even search patents for a prior solution, to find out if it's covered, because if they can show that you knew a patent existed they can hit you for triple damages.
    Instead of everyone using the demonstrably superior HSD system, we have a situation where every car company (barring Ford, who effectively developed it independently and had something Toyota wanted in the form of diesel patents) is trying to come up with their own hybrid scheme. The arguments are frequently spurious.
    There's just no way that Toyota will license HSD to Honda on reasonable terms, and no way that Honda will beg Toyota for it. Honda will be producing ASSIST hybrids until the Toyota HSD patents expire.
  9. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    It just keeps getting better. :)
    Before we know it, 90% of cars on the roads will be hybrids.
    Hybrids. The next big economic boom?
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    Thanks for the thoughtful post Mike.
    No doubt it will be easier for Toyota to adopt Honda's smart ideas that the reverse for now, but good ideas *do* spread, if slower than you or I might wish for.
