Prius-class Shuttlecraft Upgrades
Discussion in 'Gen 2 Prius Main Forum' started by Doc Willie, Oct 19, 2007.
  1. Doc Willie
    1,717
    144
    Out there, somewhere
    To: Zhang Heng Shuttlecraft Crew and Maintenance Personnel
    From: Commander Montgomery Scott, Chief, Starfleet Vessel Upgrade Program
    In addition to the refit of Constellation-class Starships, the Upgrade Program has tested and installed upgrades to Prius-class shuttlecraft. Additions to the Zhang Heng as received from the contractor include:
    1. Structural Integrity Reinforcement: This can be identified by a double X-braced plate slightly aft of amidships on the underside of the shuttlecraft.
    2. Velocity Transducer Outlets resized: Permits better control of warp engine vectors by increasing the warp space interface.
    3. Engineering Auxiliary Computer: Permits additional monitoring of warp engine and mission parameters.
    4. Main Screen Security Access: This procedure has been simplified, eliminating repetitive and unnecessary security measures , and enabling stellar cartography functions during transit.
    5. Inertial Dampening Security Sensors: Disabled since Starfleet Regulations require the engagement of the inertial dampening system at all times during operation of the shuttlecraft.
    6. Aft Motion Warning System: The installed internal warning system has been de-activated and replaced with a system that is detectable both inside and outside the shuttlecraft.
    7. Subspace Communication Upgrade: The external subspace antenna has been replace with a unit that is less subject to external damage, and which (minimally) improves warp efficiency.
    8. Intermix Pre-Heater: Installed by MiddleEarth and Conflagration engineers, it takes energy from SpaceDock reactors, to increase the Intermix Chamber temperatures to near warp capability, allowing faster engagement of Warp Drive on leaving SpaceDock.
    9. Velocity Transducer Aerodynamics: Aerodynamic rotational disks have been added to decrease drag in atmospheric environments.
    10. Main Viewer Shield: Filters photonic interference from the Main Viewer.
    11. Antigravity Generators: These emit blue photons during operations, visible from the underside of the shuttlecraft.
    12. Weapons and Engineering Controls: Bridge Audibles, Photon Torpedoes, Phasers, Transporters, Warp Drive, and Alert Status are now visible via the Main Viewer.
    13. Rear Loading Dock Access: The interface between the access and the aft shields has been reinforced.
    14. Liquid Container Receptacles: Buffering has been added here and in the internal access grips of all 4 personnel access hatches, which are also occassionally used as storage areas, particularly for personal communicators.
  2. bwilson4web
    16,012
    Please check the star chart at:
    http://willieyee.com/ZhangHeng.html/
    It looks like a 403 entropy field.
    BTW, I have a similar Spacedock power coupling but I'm planning to use a nanobot to provide a warp engine, jump start when a Spacedock reactor and coupling is not available. Also, I should have a prototype, auto-docking system soon not so much for chamber preheating but also topping off the antimatter chamber.
  3. pmanza
    pmanza Fernsmom
    123
    Sacramento
    <div class='quotetop'>QUOTE(Doc Willie @ Oct 19 2007, 11:22 AM) [snapback]527832[/snapback]</div>
    Ok I'll identify myself as a partial Trekkie and take a crack at it.
    1 - BT stiffening plate
    2 -
    3 - added PC
    4 - Nav hack to allow entry while driving
    5 - seatbelt beeper turned off
    6 - back-up beeper turned off, outside beep installed
    7 - sharkfin antenna
    8 - ebh
    9 - new wheels
    10 - window tinting
    11 - underbody light kit?
    12 -
    13 -
    14 - pads in bottom of cupholders
    How'd I do?
    Fernsmom
  4. treehggr
    treehggr New Member
    230
    <div class='quotetop'>QUOTE(fernsmom @ Oct 19 2007, 12:15 PM) [snapback]527856[/snapback]</div>
    12 - I'm guessing would be a CAN-View maybe?
  5. tlaine
    tlaine New Member
    63
    NE Texas
    13 - Rear bumper protector
  6. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Here's my attempt:
    1 - BT plate
    2 - New tires
    3 - ScanGauge
    4 - Nav override (Coastal?)
    5 - Disable seat belt alert
    6 - Reverse alert disabled and replaced with external beeper.
    7 - Sharkfin
    8 - EBH
    9 - Custom hubcaps
    10 - Window tint, or MFD hood?
    11 - Underbody light kit
    12 - Can View
    13 - Bumper Cover
    14 - Cupholder pads
    Not sure about 3 and 12, I could have them switched, or one of them might be wrong.
  7. GeekEV
    GeekEV Member
    417
    NorCal, USA
    <div class='quotetop'>QUOTE(Danny Hamilton @ Oct 19 2007, 01:27 PM) [snapback]527876[/snapback]</div>
    I was going to say a new muffler... But it could be tires.
  8. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(Danny Hamilton @ Oct 19 2007, 03:27 PM) [snapback]527876[/snapback]</div>
    Ooh, that's good. I was thinking mudflaps or air dams for #2, but new tires make more sense. I'm also thinking Scanguage for #3, but #12 refers to main viewer, which based on #10 being window tint implied a heads-up display or something I'm not familiar with, but if #10 is the MFD hood like you say, then #12 could be canview, or just access to the diagnostics/setup screens.
    MiddleEarth must be Hobbit?
    <div class='quotetop'>QUOTE(bwilson4web @ Oct 19 2007, 01:46 PM) [snapback]527844[/snapback]</div>
    I ran into the same 403 exclusion shield, some kind of cloaking device as no images could be brought onscreen.
    EV mode and battery charger?
  9. Bob64
    1,540
    93
    Virginia
    BT plate
    EV mod
    Scangauge
    Pictures under sunvisor
    Seatbelt beep off
    backup beep off
    sharkfin antenna
    EBH
    "racin" hubcaps
    sunblocker/polarizer screen for MFD
    underside lighting (led?)
    CD with track named as such inserted (with hopefully a "we're coming out of warp captain" sound)
    trunk top bumper protector thing... spells prius if you've ever noticed
    cupholder padding
  10. bwilson4web
    16,012
    <div class='quotetop'>QUOTE(nerfer @ Oct 19 2007, 04:17 PM) [snapback]527900[/snapback]</div>
    Somewhat like EV mode. I'll still have the chamber preheater more for lower lubrication drag but think of the antimatter chamber filling as PHEV-lite.
    Instead of starting off each morning at whatever the overnight self-discharge leaves the traction batteries, start off at 78-79% of full. This reduces the amount of warm-up anti-matter needed to compensate for traction battery self discharge and the depleted levels after docking the night before. I like to EV the last mile in the evening.
  11. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    This haves effectiveness of implement primary/secondary auditory feedback control system does improve for orange conditions typical of unfortunate circumprius conditioning of external. Option of "Hello Kitty" popular variation also package availables. The assistance of vision impulse conditions. Does not replace of warp auditory safety implement. Hello Kitty.
  12. Bob64
    1,540
    93
    Virginia
    you guys can fix the broken link by removing the trailing /
  13. Doc Willie
    1,717
    144
    15. Stealth Mode: Although Cloaking Devices are outlawed by Federation Treaty, shuttlecraft are stealth enabled, allowing impulse-only mode for short distances which leaves no auditory or warp engine trails.
  14. GeekEV
    GeekEV Member
    417
    NorCal, USA
    <div class='quotetop'>QUOTE(Doc Willie @ Oct 20 2007, 01:49 AM) [snapback]528121[/snapback]</div>
    See? Now that's the EV Mode mod... #2 can't be EV Mode...
  15. Bob64
    1,540
    93
    Virginia
    mebbie 2 is an upgraded gas pedal
  16. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    MiddleEarth: guilty!
    As our engineering staff has extensive experience with 403 subspace
    cloaking fields, we've also designed mitigation strategies for users
    on either end of the torpedo tube. The enemy can generally de-cloak
    the contained objects by collapsing the excess space inside; this
    has the amusing side effect that much of the forward viewer appears
    to become filled with the string "%20". But it works well. Now, if
    the defender of the web outpost wants to make sure none of the
    surrounding field is cloaked in the first place, the excess space
    can be mapped and then modulated to represent some other glyph,
    which should underscore [hint] the stasis-field presence of the
    nearby objects and require no additional types of scanning.
    _H*
  17. Bob64
    1,540
    93
    Virginia
  18. Godiva
    Godiva AmeriKan Citizen
    10,339
    BT Plate
    New Tires, different size than OEM.
    CanView
    Whatever that thing is that unlocks the screen so you can use NAV while driving.
    Disabled the seatbelt beeper.
    Disabled the backup beeper. Replaced with a backup beeper that can be heard inside and out. Possibly in one of the rear tail-lights.
    Replaced antenna with a shark fin.
    Engine Block heater installed. Installed by Fire-engineer.
    Put racing disk wheel covers on wheels.
    MFD hood. (From Priushoods?)
    Installed blue underbody lights. LED?
    Scangauge
    Bumper guard.
    14. Liquid Container Receptacles: Buffering has been added here and in the internal access grips of all 4 personnel access hatches, which are also occassionally used as storage areas, particularly for personal communicators.[/size]
    Padded all of the cup holders including door pockets, for occasional cell phone storage.
    EV switch.
  19. Doc Willie
    1,717
    144
    Congratulations, cadets. You are now authorized to operate and maintain the Prius class Zhang Heng.
  20. Godiva
    10,339
    <div class='quotetop'>QUOTE(Doc Willie @ Oct 21 2007, 04:35 PM) [snapback]528551[/snapback]</div>
    I think you mean #12, not #13.
