Prius Clear Coat Bubbling and Peeling - 2008 Light Green
Discussion in 'Gen 2 Prius Main Forum' started by coolprius_saidnobody, Oct 13, 2018.
  1. coolprius_saidnobody
    coolprius_saidnobody Junior Member
    Arizona
    2024 update. The whole roof and hood has peeled fully, and it’s working its way down the sides. I took it to a clear coat restoration place and they said unfortunately the paint on the roof (where it started) has gone with it, so it would need a repaint. IMG_2853.jpeg IMG_2849.jpeg IMG_2851.jpeg I now see Priuses driving around here daily that have the same issue. Toyota has finally addressed the white paint peeling issue on older Highlanders and Priuses. I wish they would look into this issue. Love my Prius so much but it looks awful!
  2. pasadena_commut
    pasadena_commut Senior Member
    3,071
    956
    Southern California
    The old single stage paints needed to be maintained (buffed,waxed) to look good, so they were a lot of work. However, they never broke down like base coat/clear coat (bc/cc) does. So when it comes to really old cars, I suspect the economics swing back in favor of single stage once the car hits the point where the clear coat fails. Also the old single stage paints were not nearly as toxic as modern paints - no isothiocyanates. Back in the day one could go to Earl Schieb or Maaco and get a cheap paint job to fix up a car, often after some body work, or if you wanted a different color. There really isn't such a thing as a "cheap paint job" for bc/cc - it requires a tremendous amount of prep work and the workers need expensive protective equipment. There is still tractor paint though, which is I think enamel. That is supposedly able to handle sun and weather exposure better than bc/cc. Lots of videos of people (re)painting their cars with it. Colors tend to be, well, tractor appropriate. I think some work trucks can still be had from the factory with paint that isn't bc/cc, but I cannot swear to it.
  3. PriusCamper
    PriusCamper Senior Member
    13,475
    5,440
    Pacific Northwest, USA
    They make a $30 epoxy like-Clear coat spray paint that you mix by pushing a button just before you spray it... But requires lots of prep work. Perhaps consider a vinyl wrap? It will also require sanding the surface so all the clear coat edges and paint chip edges are gone first, but easier in terms of not having to worry about color damage to the paint underneath.
