Prius completely freaked out today
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sipnfuel, Nov 16, 2011.
  1. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Hey guys, today I got into my car to get lunch.
    I got in, stepped on the brake pedal and press the power button. Then the Prius ICE started, it started clanging and violently shaking the entire car.
    The clanging was sounded like metal on metal or something, it was loud and it was like the engine was seizing up.
    I stepped outside and the whole front end was buckling up and down.
    From my perspective, it seemed like the car wanted to lurch forward if I didn't have the parking brake engaged. I had Park engaged and also the parking brake on.
    I thought it would go away but it persisted. I turned off the car and immediately restarted. When the ICE started the 2nd time it felt a bit rough but finally the clanging noise went away.
    I didn't have time to look on my scanguage for any codes during the event.
    What the heck was going on? Did this cause any permanent damage?
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Sounds like you just experienced the infamous cold start issue that can be very disconcerting by most folks accounts including mine. Luckily I had read about it here or I would have unpack the car and family as we were leaving on a week long 1200 mile trip, had it towed to a dealer, and taken our other car. Never had it since but I know now how to avoid it.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    If your front end buckled as you said, I would call that permanent damage.
    If you meant "bucking", then no, you probably didn't do any damage. The Gen III Prius has a reputation for doing this once in a while. Several threads discuss this in detail
    Tom
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Search the topic. There is alot of info you can read.
  5. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Sorry I was typing fast. Bucking is the right term.
    What is the loud metallic banging noise though? It sounded like metal on metal grinding also. Didn't sound good.
    Edit: I just changed my oil and haven't driven more than 3 miles since then, so I think it's related.
  6. qbee42
    18,058
    3,081
    Northern Michigan
  7. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
  8. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Join the club. :)
    How many miles do you have on it?
  10. Pri4Us
    Pri4Us Junior Member
    82
    Tierra Buena, CA
    Two excellent questions.... and you also have the distinction of being at least the 200th PriusChat member to report this anomaly according to the tally I've been keeping.
    Unfortunately, we here can't answer either of your questions and to date Toyota engineering hasn't shared any explanatory information which would allow Gen 3 owners to avoid this issue or if we should pursue a remedy via Toyota or its dealerships.
    So far, this anomaly most commonly occurs immediately after a cold soak of an unknown number of hours following an incomplete ICE warm-up cycle.
    Others who've experienced it have reported it followed a recent oil change. It also seems to be reported here more frequently in the fall, which has led some to think it may be associated with seasonal fuel formulation modifications by gasoline refiners.
    Dealership service staff most often claim they've never heard of this problem; but I find that a bit hard to believe given that it's been reported here on three different boards and 24 distinct threads by 200 owners... and one should take into consideration the fact that PriusChat is only known and utilized by a small fraction of all Prius owners worldwide.
    Come on, Toyota... let us in on the dirty little secret.
  11. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    10k
    I got my 10k oil change yesterday and my car wasn't driven more than 3 miles when the event occured.
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Mine had about 1K - 3K range when it happened to me (twice).
  13. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    I had to chortle regarding the bolded part. It seems SO common for dealers to say that for many problems.
    The posts I linked to at http://priuschat.com/forums/gen-iii...6-nav-system-worth-1800-a-11.html#post1316654 and podcast segment I refer to at http://priuschat.com/forums/gen-iii...s-dvd-upgrade-version-11-1-a.html#post1411937 are basically why it needs to get logged in Toyota's database.
  14. Superdrol
    Superdrol Member
    399
    32
    Mine did this when I had about 2-4k miles on it. Not long after I bought it and it only happened once. My guess would be there is an electronic design flaw and something (possibly the cold and the sensors that get effected) in the start up.
    It sounds and reacts like misfiring of engine cylinders. Even the jarring of the car is similar so that's why I think it is an electronic flaw that is caused somehow.
    On a side note, if your interior plastic parts start ratting more once it gets very cold this winter that's normal too.
    The Prius is the third Toyota I've owned (Camry, Corolla, and now Prius) and this will likely be the final purchase form Toyota. The quality of the cars is really missing and what defined the brand many many years ago. They have lost their way through time which such a shame. Now they are just an Big 3 quality car masquerading as a high quality foreign car.
  15. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    When this happens it is usually (but not always) after the car has been run for a brief time then allowed to cool off. I have had several occurrences and it has always been after I run the car for a short time, to relocate it in the driveway for example, then let it sit overnight.
    Toyota won't admit the problem exists even though it must have been reported thousands of times by now.
    Cause is unknown, some suspect an ignition problem others think it is due to fuel left in the intake system when the car is shut down.
    I have discovered a "work around" that makes it stop when it happens, at least in my car. As soon as it starts banging around I floor the throttle and it clears right up. Give that a try it works every time for me.
  16. bisco
    52,695
    i have to completely disagree with this. i'm not discounting your experience, and i have certainly read all the complaints with the gen III, but in the last 10 years, we have owned 2 camry's, 2 pri and 1 hycam. all have been some of the finest examples of automotive engineering and manufacturing quality that i have experienced in the last 40 years of driving. and i will keep purchasing toyota's. (until i have an experience like yours:))
    scona likes this.
  17. blisspacket
    blisspacket Junior Member
    32
    StAugustine FL
    What's the procedure to report this to Toyo??
  18. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Have you checked your dipstick since the incident? It's probably not the oil, but you should at least check!
  19. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    My 2007 Camry Hybrid would also do this on occasion.
