Prius coolant temperature
Discussion in 'Gen 3 Prius Technical Discussion' started by Markku Utriainen, Oct 22, 2012.
  1. Markku Utriainen
    Markku Utriainen New Member
    Hi! What is the easiest way to get and see coolant temperature of my Prius 2012? The type of my Prius is mixed three, four and five because we have different types of Prius brands in Finland and in Europe. I don`t need any other info!
    Markku
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Get an app called Torque for any smart phone. Use it with the Kwki OBDII Bluetooth adaptor or a ScangaugeII.
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The above or just a Scangauge II. Either will give you coolant temp, or any OBDII reader that can display standard outputs. It's one of the standard outputs on the OBDII buss. These must be available in Finland, they are everywhere else.
  4. Markku Utriainen
    Thank`s!
    I installed to my Nokia 700 phone OBDAutodoctor software and ordered ELM327 OBD bluetooth reader, total costs 21,90 €. There is also pro-version of the software and that costs 10 €. I`ll start with newbie version because it is free.
    Markku
  5. larrypcmc
    larrypcmc Junior Member
    44
    wi
    I use a low tech approach. I have a cheep remote meat thermometer with the sensor epoxied to the outside of the power inverter under the hood with the readout under the center counsel.The power inverter is cooled directly from the radiator so you get the coolant temperature. It seems always to be 20 degrees f. above the outside temperature after the car has been running for a long time.
  6. David Beale
    5,963
    1,990
    Edmonton Alberta
    You're seeing inverter coolant temp., which is very different from engine coolant temp. And had better stay so! The inverter coolant part of the radiator is separate from the engine coolant part.
    Engine coolant is allowed to warm up, and kept around 85C or 190F, by the thermostat and fans. Inverter coolant is kept as cool as possible.
    sfv41901 likes this.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    What David is very true.....the engine coolant & the inverter coolant are completely separate.
  8. markabele
    5,084
    1,782
    Nebraska
    What is the "healthy" range of the inverter coolant temp? And what would be too high?
  9. David Beale
    5,963
    1,990
    Edmonton Alberta
    You'd have to look up the semiconductors used in the inverter to get a definitive answer, but the general rule is if you can put your hand on it and hold it there it's fine. If it's too hot for your hand it's too hot for the semiconductors.
    The hotter they run the shorter their life. Except when they reach a certain temperature they fail immediately. The actual temperature depends on the design (how close they are operated to their maximum ratings). I would be -very- worried if the inverter coolant was running above 80C and would expect imminent failure at 100C!
    Do keep in mind inverter failure from normal operation is very rare. There were cases of inverter failure from cooling pump failure, so monitoring the temp. is probably a good idea.
  10. markabele
    5,084
    1,782
    Nebraska
    Sounds good, I just added it to my Torque screen.
  11. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
  12. markabele
    5,084
    1,782
    Nebraska
