Prius details and specs questions
Discussion in 'Gen 3 Prius Main Forum' started by darkleafar, Jun 26, 2009.
  1. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Correct, you can't. The LED is a completely different setup. You do have options on the bulb you use though as some give off a different tint.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Yup, in a IV you will have Halogens... Nothing to be mad about though, they are projector beams and work quite well from everything I have heard.
    And no, you cannot just stick LED bulbs in there... And it wouldnt be as easy as changing out the whole headlight assembly either, the LED headlights have an auto leveling system which the Halogens do not.
  3. Tideland Prius
    16,677
    Well the others have given you the answer. The bonus is that kids can't imitate it cause it's too expensive so you won't have rice rockets with aftermarket LED headlight kits (at the moment anyway).
