Prius died on freeway. 3 lug nuts missing, is this the cause?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Branndon, Jun 28, 2013.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    It says
    I am attaching the PDF of the warranty booklet. "Inverter with converter" is also in the parts list of the Federal emission control warranty, with the same footnote "Covered under the Hybrid System Warranty for eight years or 100,000 miles, whichever occurs first." So I think the answers to my questions in the earlier post above are that the inverter should be in the parts list for the CARB states and that it should be covered up to 15 yrs/150K miles, since the only exception spelled out in the booklet was the hybrid battery (10 yrs/150K miles).
    Patrick Wong likes this.
  2. Patrick Wong
    18,213
    6,530
    I agree with your observation, after reading the entire booklet (thanks for posting the pdf.)
    Yes, I think this is a reasonable conclusion.
    2009Prius likes this.
  3. Branndon
    Branndon Junior Member
    81
    Orange County, CA
    Follow up, they got it covered under warranty, and I should have the car back by tomorrow. Thanks everyone who contributed to trying to find the problem!
  4. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    That's terrific!
    Thanks for the follow up!
    Branndon likes this.
  5. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    It's always good news to hear that the repair was covered under warranty through Toyota! Thanks for the update!
  6. Branndon
    81
    Orange County, CA
    Just got the car back, and looking at the paperwork, that seemed to be the only problem. Thanks for all the advice everyone. I bought a new batter, probably unnecessary, but my old one was 3.5 years old anyway. Is there any problem with going with a standard battery type rather than an optima?
  7. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There are there are 4 issues to consider when replacing our little Prius 12v battery:
    1. Size - it is a 51R where the "R" stands for reversed terminals (positive on the left with the terminal side facing you). This also means that the total capacity is reduced (about 30 amp-hours) and you should look for a battery that can tolerate deep discharges.
    2. Terminals - It has the smaller Japanese style terminal posts versus the SAE standard terminals.
    3. Chemistry - As the battery is in the passenger compartment, the sulfuric acid is contained within an "Absorbed Glass Mat" (AGM) to contain possible spills.
    4. Vented - Again due to the battery being in the passenger compartment, the battery is "sealed" so that in normal circumstances no gasses are released and vented to handle any fault condition the releases gasses due to excessive internal pressure via a vent tube.
    There are several batteries that address all of these requirements. The three most popular ones are:
    1. Optima DS46B24R yellow top - a spiral wound battery AGM that is rugged, but a bit expensive
    2. Exide Edge 51JIS Flat Plate AGM - A cost effective alternative
    3. Toyota OE Battery - Dealers tend to overcharge for their battery
    JeffD
  8. Branndon
    81
    Orange County, CA
    Well, the terminals on the old optima were the larger, standard sized terminals, so the new battery I got also has these larger terminals. I'm sure it's not one of the three you listed, rather another small battery with the terminals in the correct position +/-. Should I do anything special to make sure it's vented? I wonder if I can order an optima online, and return this one still... I'll find out.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Well, I think we can safely put the "It was the Lug Nuts" theory to bed.
  10. richard schumacher
    7,686
    1,068
    United States
    But it does leave open an important question: why did the inverter fail? The first suspect is the inverter's cooling system. Make certain that the dealer makes certain that it is operating correctly (pump, plumbing, adequate coolant, etc.) before you take the car back.
    edthefox5 likes this.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Uart is correct. I bet they clamp off the coolant hoses on the Inverter too.
    Take some Inverter coolant out with a turkey baster and look at it in a clear jar. Cloudy needs to be changed asap.
