Prius died on the way home...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AngelFish, Mar 2, 2006.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    If the brake system detects that it has failed, either factually
    or erroneously, it's got a little !loud! beeper mounted next to
    it that it sounds to warn you that you've lost ABS and other
    braking features. If you look up past the brake pedal under the
    dash, you'll see the brake computer with a bunch of connectors, and
    a little white box with a small round grille in one side. That's
    a dedicated noiser for the brake system.
    _H*
  2. AngelFish
    AngelFish New Member
    119
    SoCal
    would that noise be a constant sound? not a 'beep' but somewhat high pitched and steady noise, only turning off when you turn off the car? If so, I did hear that...
    So far, no more issues with her. I got her back 3 days ago...... knock on wood.
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    P0607 Control Module Performance
    circuit description: DTC 0607 is stored when an internal abnormality of the hybrid vehicle control ECU is detected.
    detecting condition: the hybrid vehicle ECU has a supervisory CPU and a control CPU inside. this trouble code is output when input STP signals to each CPU are different for 0.15 seconds or more.
    trouble area: hybrid vehicle ECU
    hint: if DTC P0607 is detected while the cruise control is in operation, the system clears the stored vehicle speed in the hybrid vehicle control ECU and cancels the cruise control operation. at the same time, the CRUISE main indicator light blinks to inform the driver of the malfunction. when this trouble code is detected, fail-safe remains on until the power switch si turned off.
    inspection procedure: replace hybrid vehicle control ECU
