Prius died suddenly
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lumpy95, Mar 17, 2019.
  1. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Just curious, is there any way to mark a thread as solved or do they remain alive forever??
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Alive forever and good to help us all out with the resolution ;).
    kc5dlo, Grit and lumpy95 like this.
  3. audiodave
    audiodave Active Member
    800
    272
    US
  4. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    Using Scangauge II, I observe two voltage states of the DC-DC HV to 12-volt system:
    When 12-volt battery is somewhat discharged OR demand for 12-volt auxiliary devices is high, the system sets voltage at 14.6+/-0.1 volt.
    If 12-volt battery is fully charged and demand for 12-volt power by auxiliary devices is low, the system sets voltage at 13.7+/-0.1 volt.
    “Summer mode” may be referring to the option to turn off the Supplemental Key System that is available in the vehicle setup menus on the central console when the Prius is in Park. I turn off the SKS and one other parasitic drain related to the key fob when parking the car for more than a week. There is still some drain, but it is much reduced when the SKS is turned off and so far the 12-volt battery has survived sitting unused up to 6-7 weeks. You must use the physical key to re-enter the car and then put the key fob right next to the main power button to re-start the car.
    Data Daedalus and lumpy95 like this.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Dr Prius shows 14.6 or 14.7 when app opens and does techstream. Both could be wrong then :D
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Id like that feature also, but it doesn’t exist. It would lower the bandwidth because we’d then stop posting the same questions over and over. I mean who doesn’t love a good ole oil weight debate all over again.
    Always use the oil weight the manufacturer recommends for your vehicle, can’t stress that enough.
    lumpy95 likes this.
  7. audiodave
    800
    272
    US
    I'm going off a USB charger in my cigarette lighter that shows voltage. It could be off but each car probably a little different anyhow.
    Grit likes this.
  8. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    No, partially correct and partially incorrect, as are you. About 14.6v in some circumstances, and about 13.6 in other circumstances.
