Prius Diesel Engine Swap
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Lachlan17, Nov 4, 2019.
  1. Lachlan17
    Lachlan17 New Member
    New Zealand
    Im looking to engine swap a prius to a diesel engine. Does anyone know the external dimensions of the prius engine so I can see if this is viable?
  2. Elektroingenieur
    2,515
    3,287
    Three Touring
    The overall dimensions of the 2ZR-FXE engine aren’t given in Toyota’s service publications (more info), but changing a Prius car to use an engine of a different design is unlikely to be practicable, even if it fits in the available space and can connect mechanically to the transaxle.
    For the hybrid system to work, the engine must have an engine control module that can communicate with the power management control ECU, the computer that controls the hybrid system, and that can operate—and just as importantly, can make the engine operate—as the latter expects. As far as I know, only the ECM for the 2ZR-FXE meets these requirements.
    See also the advice in a previous thread.
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Is it true that diesel puts out more pollution than regular gasoline when ignited?
  4. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "Im looking to engine swap a prius to a diesel engine. Does anyone know the external dimensions of the prius engine so I can see if this is viable?"
    ONLY in New Zealand, home of the jet boat and Burt Munro! ;)
  5. PriusCamper
    PriusCamper Senior Member
    13,025
    5,293
    Pacific Northwest, USA
    Prius are refined so much in order to get maximum MPG that any engine mod that throws off the sensor parameters the tiniest bit will throw error codes and shut the vehicle down or put it in limp mode. 90% of the hundreds of hours it would take to do this will be based on trying to make all the sensors tell the ECU that everything is normal.
    If you want to modify a Hybrid car, buy a Gen 1 Honda Insight, which is an all aluminum and plastic car that only weighs 1,800 pounds and will let you do all kinds of great mods in ways that don't throw error codes, and if they do throw codes, it won't disable or put you into limp mode like a Prius does.
  6. Lachlan17
    New Zealand
    This would be an engine and transaxle as there would be no way a prius transaxle would be able to handle a high amount of torque. and there is No need for the hybrid. Just wanting to know how big the space in the engine bay is to see what engine i could fit.
    If the engine swap was viable a standalone ecu would be the most likely solution as the hybrid system at that stage would be 99% impossible to fit.
    and is it true that there is no real way to recycle car batteries at the rate that we are manufacturing in this day.
    #6 Lachlan17, Nov 4, 2019
    PriusCamper likes this.
  7. testriderchuck
    testriderchuck New Member
    E washington
    Who told you that? Car batteries are recycled all the time, that's why they charge you a core charge when you buy a new one. Imagine the apoplectic fits the environmentalists would have with all that lead going into landfills?
