//// TDI Prius ////
Discussion in 'Gen 2 Prius Main Forum' started by Andyinchville1, Sep 15, 2019.
  1. Andyinchville1
    Andyinchville1 New Member
    Virginia
    Hi All,
    Recently I came across a wrecked 2003 Jetta TDI and thought about getting it for the engine to do an interesting swap.
    I drive doing delivery work so maximum mileage (and durability) means maximum savings.
    I currently have 2 cars that can fit everything I need to haul... the smaller one being a 1996 Geo Prism (4 door rear seats removed for space) and the other being my 2003 Jetta wagon which still needs TLC.
    Since my Wagon was down (soon to be fixed), I had briefly looked into getting a Toyota Prius ... they get really good mileage, have space, and use cheaper fuel to boot (yes they can be modded to handle better too .... been researching!).
    Anyways, I came across a 2006 Prius with a blown engine the owner was getting rid of and the ol brain started clicking!
    I think the TDI into Prius swap would be "better" mileage wise (aero and hybrid abd diesel) BUTwould be a bit harder because an adapter plate would have to be fabbed to attach the TDI to to the hybrid drive not to mention the need to change the TDI output shaft (via adapter?) to get
    Anyways, what do you all think ?
    For potential Prius install , does anybody have a schematic of the TDI engine to Transmission bolt pattern and engine output shaft specs?
    I have contacted a custom fab co and hopefull they could fab an engine to cvt adapter plate and machine a custom flywheel / plate assy.
    Also I have never seen it posted anywhere as far as final drive ratios are concerned but what types of engine RPMs are Priuses in this generation doing at typical highway speeds.. I was just trying to determine the relative gearing of a Prius versus a stick shift TDI car. ( if anybody could post engine RPM versus speed that would be great I could probably back figure effective gear ratio based on tire size.
    Can the cvt handle the extra power and torque of the TDI?
    Let me know what you all think .... my helper is a pretty handy guy and between we have all the tools needed to fab and tinker with just need technical assistance.
    Thanks in advance for any and all help.
    Andrew
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    You would have a better chance of building a rocket and starting a colony on Pluto. Now to the seriousness of it:
    You would invest more money into this than it would take to buy a brand new delivery vehicle. Everything from a complete fuel system change out to all the sensor inputs for the hybrid control. It would take a mountain of cash, and even then probably wouldn't work. A Prius drivetrain is nowhere even related to a normal vehicle when it comes to transaxle/engine/HV system/Hybrid control/ sensor interaction, etc. It's an engineering marvel and is definitely not conducive to modifications. At all....
    and just to put it out there, the electric motor is rated for 295 ft-lbs of torque from 0 to 1200 rpm.. If I remember correctly, isn't that more than most TDIs?
    #2 TMR-JWAP, Sep 15, 2019
    52,863
    i think it's brilliant. will be following your retro mod, all the best!(y)
  4. PriusCamper
    PriusCamper Senior Member
    13,467
    5,436
    Pacific Northwest, USA
    If you're good at welding and skilled at eliminating error codes by fooling the computers it'd be fun to see you succeed. But you're literally going have to remove the entire wiring harness, fuel and exhaust system, almost all the dash electronics and not have a back seat because the battery pack would replace it.
  5. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Wow, that’s ambitious!
    I’m a firm believer that you can do anything you like (in the automotive context) if you hose enough money, calendar squares and sweat into it.
    A few observations:
    • This will not save any money. This is the kind of thing an experienced mechanic does when he/she wants to show off. You could drive it 200k miles and never earn back what the fab work & ECU coding is going to cost.
    • Getting measurements and diagrams from the internet will help, but it’s no substitute for popping out your own engine and taking your own measurements. Most transplants require multiple test fits anyway- it’s normal to try to fit the engine in there a few times before you find all the problems and come up with solutions to each of them. Don’t think for a second that this will be done in a week. I’ve been the helper on a few budget-limited transplant projects. They all required months of both-cars-taken-apart downtime, and those were old low-tech cars. If we hadn’t been required to work on other stuff for income maybe we could have done it in 2 weeks.
    • The 1.9 TDI seems to wear a lot of accessories on its nose, and is consequently shifted towards the center of the engine bay in its native applications. You can’t get away with that in the Prius, need room for the longer hybrid transmission. Granted you aren’t going to need a few of those accessories anyway. You’re starting with a tight fit given that the TDI block needs to be a bit longer for its timing gallery.
    • Some states have restrictions on engine swaps, and the general rule of thumb is that the new engine must be same or later model-year than the original, for emissions purposes.
    • I recall that a Prius engine redline is rather low- maybe 4000RPM? Will the TDI be properly useful if you somehow get it to obey the Toyota hybrid ECU and thus stay under that limit?
    • I expect you’ll need to create an interposer ECU that interacts with the TDI on one end and then with the Hybrid ECU on the other. That’s going to be a big challenge- how to map various conditions and behaviors so that the Toyota stuff isn’t constantly thinking there’s an error even though the VW is operating normally.
    • Prius engines have trick valvetrains to reduce compression during startup, to make in-flight restarts less jarring. That would be a tall order. So I would anticipate whippty-thud-BANG starts. All the time.
    • Extra torque from the engine is problematic, for proper operation of the Toyota CVT there needs to be an appropriate counter-torque created by the electric drive. You can theoretically reprogram the Toyota stuff to use some extra mustard, but it might be a better fit with one of the larger hybrids like the Camry or Highlander- they have bigger batteries capable of supplying more of that backing torque. Probably better just to have your interposer ECU restrict the output of the VW and then lie to the hybrid ECU.
    • A 2006 Prius is going to have hybrid battery trouble soon. Plan on a few grand extra to deal with that.
    #5 Leadfoot J. McCoalroller, Sep 15, 2019
    Data Daedalus likes this.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Look at what a Hybrid transaxle hopes to solve, and you will realize why there are no diesel hybrids.
    The Prius engine is an Atkinson cycle engine, very good efficiency, but no low end torque and very limited high end RPMs. (Gen 1 4500 RPMS, Gen 2 5000 RPMs, Gen3 5200 RPMs)
    The Diesel will have great low end torque but be hard to start. It will change RPMs slowly.
    The transaxle adds both horsepower and torque the the engine, an electric motor has maximum torque at 0 RPMs. The electric motor loses torque with RPM, many gas engines gain torque with RPM. Diesels torque peak is often under 2000 RPM. So a diesel Hybrid would have gobs of low end torque but no top end at all.
    Motor/Generator1 is sized to start a 1.8 litre gas engine. Starting a similar size Diesel would take a larger M/G1. (I am guessing this is a $4000 problem)
    As a rule, Diesel engines are started less frequently than Hybrid engines. There tend to be more steps and it tends to be a longer process. All the timing of starting the engine would need to be reprogrammed. (I am guessing this is a $100,000 problem. Read this: How to Start a Diesel Truck: 5 Steps (with Pictures) - wikiHow)
    As a reliability issue, the Prius does not fire the spark plugs until the gas engine is up to speed. As the diesel has no spark plugs, you would need some other method to get the engine up to speed before firing (not injecting fuel?)
    There is a reason almost all hybrids use Atkinson cycle engines, the weaknesses of the engine are complemented by the strengths of the Transaxle. (The is similar to the fact that almost all diesels are turbocharged, the strengths and weaknesses play into each other)
    1) I think the design difficulties will be overwhelming. 2) I do not think the results would be efficient. 3) I would be happy to be proved wrong.
    Atkinson cycle - Wikipedia
  7. Andyinchville1
    Virginia
    Hi
    Good input so far ... appreciate the help...
    Getting some help from the tdi folks also ( I'm actually more familiar with the TDI than I am the Prius because I used to drive a TDI Station Wagon until mine started acting up).
    I did see a YouTube video explaining how the CVT transmission works in a Prius and I thought it was rather strange that to get different gearing a motor actually has to offer resistance ... I guess it's hard to wrap my head around a planetary gear set to start with but i understand the bottom line needs tho.
    As far as being able to start and stop the TDI engine, that's not necessarily a problem because how you stop the engine is basically cut power to the fuel injection pump and that effectively turns the engine off because cutting the injection pump power stops the fuel flow ( it's basically how the TDI engine stops in the first place even in a stdTDI application).
    Cold start may require separately starting the diesel engine and letting it run a bit before having the auto start and Auto Stop function work but in theory that wouldn't be hard because the tdi engine has its own starter independent of mg1.
    It has been suggested over at the TDI Forum , to limit the power of the TDI engine itself , the turbo could be removed ... less boost pressure means less Fuel Volume means less power ... I suppose in theory reducing the power of the diesel engine makes it easier on mg2 to make for a better better gear ratio .
    A side benefit of removing the turbo is less space underhood is required...
    While would be even more costly, and in an effort to further reduce low-end diesel torque which is inherent in a diesel engine I wonder how incredibly efficient and Atkinson cycle diesel engine would be I understand custom Pistons and a custom cam would be required but for somebody seeking maximum efficiency and fuel mileage I would think that would be the hot setup at least as far as internal combustion engines go ... ( an atkinson cycle diesel engine).
    Before I have my car towed off to the shop I may actually take a tape measure to the engine and see if it can sit in the Prius engine space in the first place...
    Keep ideas coming I appreciate all the constructive input ...
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    60 MPG is rather common from the latest generation. How is "better" defined in your regard?
    Don't forget about emissions either. A repurposed diesel in a junk titled vehicle may not get approved for road registration.
  9. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    How about modifying a Jetta hybrid?
  10. qettyz
    qettyz Active Member
    181
    208
    Finland
    Mercedes sells Diesel hybrids at europe.
    They sure have to have quite different program for keeping diesel engine at right temps, start it, run it correct rpms etc.
    Installing diesel engine to Prius would need quite bit programming to multiple ecus i believe.
    But hell, i wanna see this project to finish!
  11. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Awesome summary, and I agree on all points. (y)
  12. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The Atkinson cycle reduces compression ratio versus expansion ratio, but a Diesel requires high compression to fire the charge. I do not think you can reduce it.
    Skibob and DMC-5180 like this.
  13. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Would be easier to put that TDI engine in your Jetta wagon and get a junk yard engine for the Prius.
  14. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Gen IIs are $50 on up for the whole engine
    wnrsm likes this.
  15. wnrsm
    wnrsm Member
    47
    27
    Virginia, US
    A blown engine should never be the death of a Prius. Those engines have a relatively easy life.
    The death of many are due to failures of the HV battery, inverter, and ABS actuator/pump. They leave behind many viable used engines.
    If you're even thinking about this crazy swap, you have enough ambition to replace the engine.
    Skibob likes this.
  16. wnrsm
    wnrsm Member
    47
    27
    Virginia, US
    Where do you find engines at this price point? My searches yield $200 or higher with local pickup that's far from me. I'm in the Washington DC metro area.
    I wonder if there is any kind of hobby that can make use of these cheap plentiful engines.
  17. Rmay635703
    2,704
    1,729
    2013 Chevy Volt
  18. bisco
    52,863
    hi andy, how's it going?:)
