Prius Disappoinment - Road/Wind noise
Discussion in 'Gen 3 Prius Main Forum' started by dschwalm, Jan 7, 2011.
  1. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hey Truman,
    We are all pretty sure this guy is a Troll. He has not replied at all to the many comments to his thread. In other words, don't waste your breath (typing) on him....
  2. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I find its road noise very quiet, but I am used to cheap entry line cars, never have owned a luxury brand and quite possibly never will.
  3. bossless
    bossless New Member
    Somewhat, but remember, Prius is not a luxury car and will be noiser than one.
  4. Seamaster
    Seamaster Member
    123
    70
    GB
    2019 Prius
    Excel
    I wonder how much road noise is communicated via the trunk area, and whether or not the rubber trunk liner Toyota offer as an accessory makes much difference?
  5. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    You think the Prius is noisy? Try driving a current generation Honda Accord, CRV, Fit, or Civic. My Prius IV is quieter than my previous 08 Accord EXL V6.
  6. viclavigne
    viclavigne New Member
    76
    Georgia
    On the contrary, I have 2 of the 2010 Prius' and they both seem quiet to me. On the interstate at 70 mph, didn't have any noise issues. In fact, my wife commented on how quiet the wind noise was while passing an 18-wheeler.
    Maybe you have a loose window seal someplace, something must be wrong to produce noise at a level you are describing.
    Vic
  7. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    Add to that list an Acura Integra or RSX. There are many things I like a lot about Hondas, but man, they gotta do something about that road noise. The Prius (other than the dash rattles) is like a tomb in comparison.
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yes.
    A Prius is not quiet compared to luxury cars, but you shouldn't have to shout unless there is something unusual about your Prius. As others have suggested, bad weatherstripping or a mal-adjusted door are two possible sources of your noise.
  9. JJB
    JJB New Member
    39
    Alpharetta, GA
    Add Pilot to the list. That's my biggest complaint about my wife's 2008. I tried installing a parrot bluetooth system, but yanked it out because the wind and road noise was louder than her voice.
  10. cobradb
    cobradb Member
    105
    tn
    noisy in Austin
    you have something wrong with your car based on your writing
  11. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I'm going to invest in Dynamat, starting with the four doors, to try and eliminate some of the road noise. I'm sure my hearing isn't what it used to be 10 years ago, but the overall din whilst on the highway is tiring -- especially since they're concrete in this area.
  12. ETC(SS)
    7,548
    The OP cannot be a troll.....
    evpv hasn't rushed in to defend him!!! :D
    2 people like this.
  13. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I have not read all of the post above, so my comments are based solely on the thread title.
    This week I have been driving a 2010 Ford Fusion (rental). It is not a hybrid.
    Prior to buying the Prius, I considered a Fusion Hybrid. I was unable to find one at the time, and the dealer was anything but interested in finding a Hybrid.
    I find the rental Fusion to be no quieter than the Prius. I personally think tires and road surface are the cause. Previously, I owned a RSX and the road noise was bad ..... until I changed tires. The Prius is quieter when climbing mountains and accelerating hard than the Fusion. The Prius brakes are far superio,r as are the lights. I really miss the Prius illumination projection ... especially since I raise the lights.
    The controls in the Fusion are confusing, and not instinctive. I have yet to learn how to change the displayed information.
    The seats in the Fusion initially felt pretty good. But after 8 hours behind the wheel, my back is complaining. I have driven the Prius several times over 12 hours without problems.
    Handling is nice; the body is tight, with only one serious rattle. The Fusion, IMO, would have been a good choice, but not a better choice than the Prius.
  14. bisco
    52,847
    thanks felt, that is a very interesting comparison. my wife has been thinking about a fusion hybrid. should be an interesting test drive compared to her hycam which is whisper quiet and better than the prius in every way except mpg and storage space. imo!
  15. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Road noise is proportional to the roughness of the pavement. I would think it takes a lot of insulation to keep out tire noise on rough freeway surfaces. Even my Accord Coupe gets a bit noisy on the rough stuff, but it's pretty quiet on smooth freeway.
    Prius is pretty quiet on smooth freeway also. I don't remember a lot of wind noise of howling - it was pretty good in that department. If you're coming from a luxury car, maybe the downgrade is a little disappointing, I don't know. Prius noise is certainly reasonable for the class of car.
  16. tumbler
    tumbler New Member
    32
    Knoxville
    Actually, the new Jetta TDIs are remarkable quiet and there is NO interior sound associated with a diesel engine. I own and sdrive a 06 jetta TDI and I drove it to work this AM instead of my Prius V (with 15-inch wheels/tires) and the Jetta is much quieter in all resopects, even after having installed sound dampening material in the Prius last week. Also, there is not one squeek or rattle in the Jetta and none, thus far, in the Prius. Guess I got a good one.
    I knew about the noise problem in the Prius and I knew I would have to install sound dampening material in it. That job will be completed in about a week and then it will be as queit as the Jetta, TDI engine aside.
  17. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    The Gen III is in fact a mid-size sedan.
  18. ETC(SS)
    7,548
    The Prius is a mid-sized sedan according to the EPA.
    (So is the Nissan Versa....)
    It doesn't matter for 2 important reasons.
    1. The OP is (was) a fake. I'll avoid using the "T" word to protect evpv's sensitivities.
    2. Size, speed, comfort....all relative, and it has little to do with your perception of whether the Prius is an Econo-box, an Eco-box, or a Luxury Sedan. The EPA had to snap the chalk line somewhere, and cars like the Versa, Prius, Sentra and Optima came in on the good side. Be happy.
    If you're used to driving an Aveo....yeah, the Prius is big and roomy. If you're used to driving a Hummer H2, then Priuses are probably rather diminutive and economical, given the H2's heft and price.
  19. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Having recently posted about my experience with a Ford Fusion rental, I just returned from a 800 mile trip to California. Concrete roads are now grooved .... and they are noisy. Talking is difficult; the radio must be elevated to hear. The "thump, thump" road imperfections are very annoying. Asphalt, especially new asphalt, is almost silent. Welcomed and refreshing.
    But the worst surface is a treatment that most of the western states are now using. They spread a thick layer of some sort of tar/oil on an existing roadway. The layer, is a black slurry type material that, no doubt, is petroleum based. On that they spread a thin layer of pea sized gravel, and roll it into the slurry. It is applied over asphaslt and concrete, and covers most blemishes, cracks, and patches. The surface is heavily textured from the gravel, very nosiy and I suspects, increases the road to tire friction. I am sure the fuel efficiency is deminished a bit. Every car that passes, regardless the size, make or model, emits a roar on the road that is easily heard inside the vehicle I am driving. I am certain the surface is durable and cost effective ................ but it is noisy. I cannot imagine that any car would be able to mask the sound.
  20. aridon99
    aridon99 New Member
    67
    San Mateo, CA
    Yep, it all depends on the car you drove before the Prius and the roads in your area. I think my 2010 Prius is pretty loud on the roads around here, but it is an economy car that gets the best MPG in the nation, so lets put it in perspective. On my G2 Prius, I tried lots of dynamat and mass loaded vinyl barriers in my car and it really didn't make a noticeable difference (just added weight and decreased my MPG). After reading multiple books on sound behavior, isolation, and dampening, I've realized that retrofitting a car to cut down on road noise is a futile game. Noise is like water. Even if you can seal 99% of the cabin, that 1% hole will make all your efforts pointless. Remember, sounds travels very very fast through that little gap and it bounces around like crazy. Luxury cars get the NVH treatment with the car completely stripped down and every aspect is looked at from the initial design. Sure, dynamat can make your speakers sound better, but is has little effect on keeping sound out of the car. It's just my opinion folks, you may pray to whichever god you like :)
    I'm working on a different solution to solve my road noise issues and the ringing in my ear (reminder of onset of hearing loss in some frequency). Once I drive the car long enough, that range of my hearing will be gone and I will no longer get the ringing :D
