Prius Eco 58 MPG vs Prius 54 MPG - What's the difference?
Discussion in 'Gen 4 Prius Fuel Economy' started by cyclopathic, Nov 18, 2015.
  1. bentbow
    bentbow Junior Member
    34
    bay area
    that sounds very believable. i don't know anything about epa testing but weight classes make sense. they don't have any real-world driving component?
  2. goinskiing
    goinskiing Active Member
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    Love my '18 Two Eco fuel economy, so far averaging 63 MPG at the pump since I've had it.
  3. Classic Car Guy
    Classic Car Guy Active Member
    429
    119
    Northwest, USA
    Congrats. That's incredible! I don't know the exact mpg on my 2007 but one time I forgot to pump the gas and I got 395 miles and it just turned 1 bar on a 50/50 city/highway driving 30 miles one way. Probably not the best but I'm very happy with it.
  4. John Kuhn
    John Kuhn Member
    45
    47
    Wisconsin
    Is that mileage for your '18 Two Eco? Because your signature says you have an '18 Prius Prime?
    Prodigyplace likes this.
  5. Gokhan
    Gokhan Senior Member
    6,210
    2,462
    Paramount CA
    Only a 30 lb weight difference between L Eco and LE, L Eco missing the rear wiper with arguably some benefit in drag coefficient, same lithium-ion traction battery, and same tires. These would hardly make a significant mpg difference between the two in the real world. I don't really trust the manufacturers' mpg tests, and I think Toyota simply biased the tests for L Eco, rounding up the numbers etc. The actual real-world difference is probably only about 1 mpg.
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,152
    6,310
    Texas Hill Country
    Back in 2015 when the op started this thread, the batteries were lithium-ion in the eco versus nickel-metal-hydride in the base model. That allowed more efficient use of energy. Today standard Prii with the aftermarket lithium battery are also seeing higher mpg.
    #246 rjparker, Jan 2, 2022
    Gokhan and Tideland Prius like this.
  7. Mendel Leisk
    41,457
    From the 4th gen get-go, other levels beside Eco had lith-ion. IIRK currently base and AWD levels have the older chemistry; all others are lith-ion.
  8. Tideland Prius
    16,557
    All other levels except Two you mean. Two Eco had the Li-Ion. Only the base Two had NiMH in for the 2016 MY (2017 too I think).
    jerrymildred and Mendel Leisk like this.
  9. Gokhan
    6,210
    2,462
    Paramount CA
    So, your theory is that in circa 2016 Toyota tested the base model (Prius Two), which was the only model with a NiMH battery, and Prius Two Eco, which had a lithium-ion battery, and none of the other models, which all had lithium-ion batteries. I guess that is a plausible explanation.
  10. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,688
    Somewhere in Wisconsin
    2013 Chevy Volt
    As the Ford fuel economy lawsuits have proved at a minimum Toyota could simply test one car in the platform and interpolate the other models with no additional testing
    Gokhan likes this.
  11. Gokhan
    6,210
    2,462
    Paramount CA
    Not even interpolate/extrapolate—equate. Note that the Touring models had 2.0-cm-wider tires, which would result in less mpg, but they all received the same mpg rating.
    Mambo Dave likes this.
  12. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    My L Eco gets almost 40 MPG. Best fuel mileage car I've ever had! :D
  13. Gokhan
    6,210
    2,462
    Paramount CA
    Coming back to this again, I don't think the battery difference is the reason. I think it is a testing/reporting artifact. I had also noticed that Prius Eco had produced a lot higher NOₓ emission during testing, which could indicate operator differences. Or perhaps something is programmed differently in Prius Eco.
    Do higher NOₓ numbers explain Eco's much superior fuel efficiency? | PriusChat
  14. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
    I think it’s both.
    A touch of lean burn plus the fact the car is on the edge of the next weight class.
    The days of a lot of people reporting fuel economy to various sites like ecomodder are long gone so comparing a large group of ecos to other PRII in the real world has become impossible.
    meaning we don’t really know how much better the eco really is and considering it’s dad are numbered it will become moot with the next gen
