Prius Eco 58 MPG vs Prius 54 MPG - What's the difference?
Discussion in 'Gen 4 Prius Fuel Economy' started by cyclopathic, Nov 18, 2015.
  1. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    I noticed this in a Motor Trend article on 10 interesting facts about the 2016:
    "To ease the load on the climate control system, the 2016 Prius comes with a heat-insulating windshield in the Eco trim to ensure that infrared ray transmission is reduced and the cabin is comfortable in hot weather. A positive temperature coefficient ceramic heater warms the cabin quickly without relying on the engine coolant to get up to temperature."
    I don't remember hearing about a ceramic cabin heater before. Has this been mentioned before?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I know it was a feature of the Gen 2 Prius, I assumed it was a feature of all since.
  3. bwilson4web
    16,204
    It is also in the Gen-1, 800 W if I remember correctly. I've got the electrical schematics at the house.
  4. Mendel Leisk
    41,413
    It's using electrons, ultimately from the hybrid battery? With our 3rd gen, don't think the heat wakes up till coolant gets to around 50C.
  5. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    not cool. Double Shotgun!
    ^ Haha! Well done. ^
    Back on topic, the I'm thinking the efficiency improvements are or could be due to...
    • Better LRR tires
    • Better engine efficiency via taller PSD gearing?
    • Better engine efficiency via less engine power required during acceleration?
    • Better aero (underbody, engine bay, ?)
    • Lower cooling (and heating) loads?
    • Tweaks to the HVAC system (maybe a heat pump for heat?)
    #145 roflwaffle, Jan 26, 2016
  6. KrPtNk
    323
    283
    Pacific Northwest
    That's interesting. I don't now have a Prius, but have tried to learn about the features of the car. The electric heater makes perfect sense. I am glad they included it in previous models. The way it was presented in the article they made it seem like a feature unique to the Eco.
    Thanks
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It may have gotten larger, in the Gen 2, it was just so defrost would work before the water temp rose. Perhaps they can actually heat the whole cabin now.
  8. bisco
    51,899
    i have never felt any heat in my 3 pri until the engine warms.
  9. AKCoffee
    AKCoffee Junior Member
    46
    23
    2014 Prius v wagon
    If it's electrically driven and in the gen 3, is it on its own circuit with a fuse I can pull or can we locate the wires so I can snip them? Sounds like energy conversion losses and extra ware and tare on the pack, , I'd rather wait for the coolant to get hot and I'm in Minnesota.
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    On my Gen 2 there were fuses, on page 48 of this PDF (page 400 of the manual) you can see 2 PTC heaters. (Positive Temperature Coefficient: the hotter they get the more their resistance rises, preventing over heating and lowering electrical draw)
    http://www.toyota.com/t3Portal/document/om/OM47614U/pdf/sec_04_03.pdf
    I did not see any fuses marked PTC Heater in the 2015 owners manual.
  11. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    GIII has the exhaust heat recovery device, so those barely noticeable 400W heaters (there were two as I recall) in the GII were not needed. I only noticed them once, on a fall day, ambient temp. just above freezing. The air the system was discharging was just barely warm. Never noticed an effect in winter. I suppose -30C air is just too much for them.
    The GIV has an enhanced exhaust heat recovery device, according to the info. posted. I suppose the electric heater reduces engine run time for warmup. That would be a big fuel efficiency gain. Most of my "fuel wasting" or "guzzling" is due to warmup.
  12. AKCoffee
    46
    23
    2014 Prius v wagon
    Which is it in G3 and G4: exhaust heat recocery (scavenging heat energy otherwise going to waste out of the tailpipe) an efficient good thing, or electric resistive heat to quick warm the cabin/cat/motor or some combination? Given the amount of current it would take to move any of those loads an appreciable amount and the energy to do so ultimately comes from the gas tank, it would take a lot of convincing to get me to believe any electric role is net positive for FE, let alone positive enough to justify stressing the pack.
  13. AKCoffee
    46
    23
    2014 Prius v wagon
    I'm no engineer maybe my assumptions are flat wrong, but 800 watts sounds like a big additional draw.
  14. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    800 watts = ~ 1 HP
    mmmodem likes this.
  15. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    The question is when do those two 400W heaters actually work, my guess is they only work when you select front defrost, with dedicated button and cooling fluid is too cold. If I remember correctly the heaters heat air directly and not the cooling fluid.
    bwilson4web likes this.
  16. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    It seems to me that tire pressure is a large reason for better mileage in the Eco. They probably must test at the recommended pressure written on the car, and I believe the pressures written on the Eco are higher than on the other models.
  17. bisco
    51,899
    i don't know how big a part it plays, but i think you are correct on the pressure and testing.
  18. bisco
    51,899
    the problem with this, is that the front defrost button starts the engine on the pip.
    roflwaffle likes this.
  19. eric1234
    eric1234 Active Member
    391
    200
    Hamden, CT
    On my 2016, I see that the fuse compartment (up front on the passenger's side) - has 2 empty spaces for PTC. I also notice that there are many other empty fuse spaces in that as well as the other fuse compartment.
    I think I once remember reading/hearing somewhere that the 2010 did have these (but honestly, I never looked). I also think I remember reading/hearing that in some instances, the Dealers failed to install these as part of the PDI (pre delivery inspection).
    So, does anyone know if: (1) My 2016 Three *should* have fuses there; or (2) It is an option on higher models or other world markets, that is not part of my US Three??
  20. Y-Zer09
    Y-Zer09 Junior Member
    24
    24
    Also, how is trim 2 NiMH getting the same MPG as the lithium battery versions
