Prius Eco 58 MPG vs Prius 54 MPG - What's the difference?
Discussion in 'Gen 4 Prius Fuel Economy' started by cyclopathic, Nov 18, 2015.
  1. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    NiMH is just heavier than LiIon, but the Two has the fewest options so the entire car is not heavier than the Three or Four. The Two Eco is lighter, in part due to the LiIon battery
    51,939
    and again, they don't test each model individually. it's like doing your taxes, report whatever you want, but if you get audited, it better be right.:p
  3. Y-Zer09
    Y-Zer09 Junior Member
    24
    24
    Its hard to believe that the two perform the same, but it does simplify things for us simple folk(y)
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  5. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    How much more expensive is the Li-Ion to replace down the road compared to the Nihm? Does anyone know?
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    NiMH costs have come down by several thousand in the last ten years, LiIon should as well. It will be a moving target.
  7. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    I know the high capacity electric RC car and helicopter Li-Ion packs cost anywhere from $100-over $300, compared to $30-80+ for high quality Nimhs.
  8. Tideland Prius
    16,559
    Toyota used to opportunity to use Li-Ion to reduce weight rather than increase output. Therefore, there's a smaller (and lighter) physical battery under the seat of those with Li-Ion batteries than those with NiMH.
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    And the -reason- they could go "smaller" (the Li-Ion has less A-Hrs than the NiMH) is because the Li-Ion is more efficient in charge and discharge, so they can operate it closer to the limits of full charge and full discharge. There are also half as many cells in the Li-Ion. That -should- translate to better reliability, but we will see in the next 5 years or so.
    So with the Li-Ion you get a multiplier effect - you can use a smaller capacity battery AND the battery uses much lighter parts so the finished part is much lighter. I still don't think even as much as 50 lb would cause a noticeable change in fuel economy. I think it is a result of the testing parameters. The weight is used in "corrective formulie" .
  10. Y-Zer09
    24
    24
    Bought my Prius Eco today. Didn't want to wait for a blue with black interior. Will post my first trip MPG tonight
    AKCoffee, GaryD1 and krmcg like this.
  11. krmcg
    2,592
    2,392
    Whittier, CA
    Great
  12. Y-Zer09
    24
    24
    Here are my first two trips.... Very disappointed (just kidding)
  13. krmcg
    2,592
    2,392
    Whittier, CA
    Excellent job.
  14. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    does display show average speed in this same pic, don't see it showing up like Gen 3
  15. Y-Zer09
    24
    24
    The exit screen does not but perhaps another info screen shows it. simple calculations come out to 28 mph average speed. It was stop and go traffic south west Florida
  16. Y-Zer09
    24
    24
    This trip was downwind most the way so it helped
    GaryD1 likes this.
  17. Y-Zer09
    24
    24
    I'm noticing it's easier to get to EV mode at 55mph + also can stay in EV mode longer when I accelerate
  18. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Compared to a non Eco Gen4 or a Gen3?
  19. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    Great stuff! Roundtrips are more realistic though.
  20. Y-Zer09
    24
    24
    Compared to Gen 3
