Prius emergency power, again
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Nov 2, 2014.
  1. bwilson4web
    16,450
    I was watching Dr. Who when the power went out in the neighborhood at 11:40 PM.
    I drove to a gas station in an area with power and 10.5 gallons filled up the 2003 Prius. I backed into the car port; set the parking brake to inhibit the daylight running lights; restarted the car; turned on the inverter and plugged in:
    • goose neck lamp for living room
    • extension cord to the gas furnace and hallway light at doorways to bedroom and bathroom
      • outside temperature, 38-40F (3-4C)
    • power strip for Mac and TV
      • charger for cell phone
      • T-Mobile hot-spot of Internet
    It is an hour later and still no utility power but we have lights, heat, and communications. In the morning, I'll put a Kill-a-watt meter and start juggling the power.
    At 1:00 AM, power came on for 5 minutes and then went out again for a minute. Since then, it has remained on and I'm normalizing the circuits. My first mod was to add an inverter. Now to turn off the car.
    #1 bwilson4web, Nov 2, 2014
    Prius_Cub and GrumpyCabbie like this.
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
  3. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Are you hooked to the traction battery? If so, will this affect the car in anyway given how intelligent it is? Ex- car sees an unusual drop in the capacity of traction battery for no known reason.
    52,606
    no, hook up is to the 12 volt. traction battery will give you more power, and the car handles it fine, but it's more complicated and expensive.
  5. bisco
    52,606
    35 and snowing, blowing a gale here. power is still on. i would have thought the weather would be better in alabama.:cool:
  6. bwilson4web
    16,450
    Normally, yes but it was clear and calm:
    Local news reported it as equipment failure.
