PRIUS ENGINE CAN'T SHUT DOWN
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dxta, Jun 10, 2017.
  1. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    everyone. I have for a serious issue with my 2008 Prius "babe".
    I was going to a grocery store to get some stuff for my little boy today, and suddenly, when I decided to shut off the engine by pressing the start/stop button, it just refused to off. No lights were coming on the dashboard, only the battery indicator light.
    I disconnected the aux battery +be terminal to see if it would go off, but it just refused my " gesture".
    What could be the reason 1) the dashboard was dark without any indicator lights showing?; 2) hiw can I get the engine of the Prius to go off?; 3) is there any lasting solution to this problem?
    Appreciate your replies greatly.
  2. SFO
    SFO Senior Member
    5,297
    4,238
    Northern California
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,337
    6,013
    Columbia, SC
    If I remember right, you should be able to get it to shut off by pressing and holding the power button. Most likely, the next time you start it up, it will probably work correctly. If it's the combo meter failing, it's typically very intermittent. I had it happen once on my son's 2005, and that was almost 2 years ago. Hasn't happened since.
    Data Daedalus, bisco and SFO like this.
  4. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    That's scary! I would be genuinely horrified if that happened to me. Has anyone experienced this recently in the U.K.? I thought this incidence was restricted to earlier models.....or was it just a bad batch of combination meters?
    iPhone ?
  5. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Next time this happens, hold the start button down for more than three seconds. If your display is not lit, you will need to repair the combination meter.
    Data Daedalus likes this.
  6. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Unplug the 12V battery while the car is running and won't shut down. That kills the car. It seems like it could harm the car, but that's what I did and I didn't have a problem after that. The speedometer wouldn't turn on either when the car wouldn't shut down
