Prius engine slightly stumbles..
Discussion in 'Gen 3 Prius Main Forum' started by Rob Stone, Feb 11, 2019.
  1. Rob Stone
    Rob Stone Junior Member
    49
    Portsmouth Ohio
    My 2015 Prius recently started a strange thing. When I let off the gas pedal to coast, the engine stumbles slightly and I feel it. When I gently press the gas, the engine slightly stumbles and starts. I can also press the gas pedal barely and hit a point where the engine stumbles slightly as long as I’m barely pressing the gas pedal.
    Another issue I noticed is when I accelerate hard on slick pavement, the traction light comes on but system is not retarding engine. I can spin the tires for a good distance...... any ideas as to how to troubleshoot this issue?
  2. JC91006
    16,933
    8,643
    Sounds like the EGR circuit/Intake ports should be cleaned. Too much carbon buildup. probably good idea to change spark plugs if you have high miles
    On your Avatar photo, what on earth are you doing there under the car?
    mjoo and Rob Stone like this.
  3. Mendel Leisk
    42,264
    How many miles?
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Traction light comes on because your tires are spinning while car is stationary thus traction control kicks in to stop the tires from spinning, feels like a horrible knock also. The way to troubleshoot is replace current tires with more grip.
  5. Rob Stone
    49
    Portsmouth Ohio
    That’s not what’s happening. Engine is not being controlled at all during tire spin. When it works right, the engine stalls to allow tires to gain traction.
  6. Rob Stone
    49
    Portsmouth Ohio
    189,000
  7. bisco
    52,776
    start of a head gasket fail?
  8. Rob Stone
    49
    Portsmouth Ohio
    That’s my son in my Avatar. Trying to remember what we were doing that day. That was our 2004 Prius.
    Raytheeagle and Mendel Leisk like this.
  9. Rob Stone
    49
    Portsmouth Ohio
    Hope not!
  10. bisco
    52,776
    me too!:)
    amos and Rob Stone like this.
  11. Rob Stone
    49
    Portsmouth Ohio
    Seems like we had to remove wheel well for something. I know we removed nose of that car to replaced headlights once....now I am going to wonder about that the rest of the evening. Lol
  12. JC91006
    16,933
    8,643
    Looks like he's turning some tool, but that area, I don't know what's there.
    But I was thinking it looks a bit dangerous to be under there using a scissor Jack
  13. Rob Stone
    49
    Portsmouth Ohio
    That’s a jack stand. We never rely on jacks to hold a car up.
  14. Rob Stone
    49
    Portsmouth Ohio
    So my plan is to replace spark plugs and inspect EGR plus EGR tubing.
    amos, Raytheeagle and bisco like this.
  15. Rob Stone
    49
    Portsmouth Ohio
    It still seems like a control module is not working right with traction control issue I am observing.....
  16. bisco
    52,776
    do the intake mani while you're in there. how's the throttle body?
    amos likes this.
  17. Rob Stone
    49
    Portsmouth Ohio
    Have not inspected yet. Will be weekend project.....
  18. bisco
    52,776
    wouldn't an eco give you a code?
    Rob Stone likes this.
  19. Rob Stone
    49
    Portsmouth Ohio
    No lights on dash. Will read codes with my code reader this week.
  20. JC91006
    16,933
    8,643
    If there are no warning lights, it shouldn't be any failing electronic systems.
    I would do a whole tune up on the car.
    1. Change spark plugs
    2. Change coolant
    3. Clean EGR circuit
    4. Clean intake ports
    5. Clean throttle body
    6. Change pcv valve
    All in a days work
    Rob Stone and amos like this.
