Prius engine slightly stumbles..
Discussion in 'Gen 3 Prius Main Forum' started by Rob Stone, Feb 11, 2019.
  1. Rob Stone
    Rob Stone Junior Member
    49
    Portsmouth Ohio
  2. Rob Stone
    49
    Portsmouth Ohio
    Here is a video of the EGR tubing conditions. The tubing is clear but there is oily deposits inside and the intake manifold has oily deposits.
  3. Mendel Leisk
    42,208
    They don't look too bad. 120K (or 12 years) was the spec.
    #43 Mendel Leisk, Feb 17, 2019
  4. douglasjre
    douglasjre Senior Member
    2,241
    749
    Null, NL
    Rob have u found the cause yet? We have a Prius w same issue. We have the misfire on cyl 4, moved plug coil pack and injector, compression tested and still cyl 4.
  5. Mendel Leisk
    42,208
    What was the readings of the compression test?
    If I've got this right: #4 piston is last in line on driver's side? This is the side EGR gasses enter.
    douglasjre and Rob Stone like this.
  6. Rob Stone
    49
    Portsmouth Ohio
    Test drove it just now, it feels like the stumbling issue improved.
    Your issue sounds like a mechanical problem that is unique to that cylinder. Compression testing is in order?
  7. douglasjre
    2,241
    749
    Null, NL
    180 all cylinders
  8. douglasjre
    2,241
    749
    Null, NL
    Why does it sound like a mechanical problem?
  9. Rob Stone
    49
    Portsmouth Ohio
    If you moved the plug and coil to a different cylinder and the cylinder remained the same, the issue is with the cylinder?
  10. douglasjre
    2,241
    749
    Null, NL
    What diagnostic procedure would I use to find it?
  11. Rob Stone
    49
    Portsmouth Ohio
    The wiring harness for cylinder 4 could have issue along with module that sends signal to that coil. So it still could be electrical problem, after I thought about it. A grounded test spark plug might show loss of spark...
  12. douglasjre
    2,241
    749
    Null, NL
    Where r the modules? I am now noticing the problem exists only after engine warmup.
  13. litesong
    litesong Active Member
    371
    122
    Everett, WA
    Since you live in Orlando, Fl., where there a plenty of E0 stations, I'd try some E0 gas before any mechanical or electrical solutions. Go to pure-gas.org for a bunch of E0 station addresses. Many WAWA stations.
  14. douglasjre
    2,241
    749
    Null, NL
    Cleaning the stuck EGR fixed the problem
  15. ASRDogman
    ASRDogman Senior Member
    7,997
    4,058
    Did you clean the EGR Cooler also? Intake?
