Prius engine vibration for few seconds after engine oil and transmission fluid change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hc167, Sep 24, 2016.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Prius is an Atkinson style engine. Corolla is an Otto style engine. Different:). Many threads here and Google will help describe the differences. The gen 3 Prius has an egr system, which aides in the complexity.
  2. hc167
    hc167 Member
    132
    US
    So you are saying the evap system in Prius is defective by designed? Or do I misunderstand something?
  3. hc167
    hc167 Member
    132
    US
    Do we know Toyota non-hybrid have similar issue?
  4. hc167
    hc167 Member
    132
    US
    OK, I knew the second gen Prius is Atkinson style. I did not know the third generation is also Atkinson. thanks.
  5. hc167
    hc167 Member
    132
    US
    OK, one more question. I remember this has to do with cold start. and when I started the car after the oil change, it was about 62-64 F. Is this consider to be cold that cause the issue?
  6. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    The knock at startup has to do with moisture or condensation collecting then getting into the combustion chamber. So it is not just temperature based but also humidity and dew point based;).
  7. bisco
    51,950
    if you don't stop your engine while it is warming up, you won't have the problem again. for more detail, seek the many threads here describing the problem.
    Raytheeagle likes this.
  8. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    When you changed the Transaxle fluid did you make sure the car was level and filled till it leaked out of the fill port?
  9. hc167
    hc167 Member
    132
    US
    Yes
  10. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    Did you overfill the motor oil?
  11. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Yes. If you shut off the car while it's still warming up, it "complains" the next time you turn it on. It must be a software bug.
  12. qdllc
    qdllc Senior Member
    1,377
    400
    On most every vehicle I've had, I find there's an odd noise when you first start the engine after an oil drain and fill. I think it's because there's "air" in the system, and for a few seconds, it's pumping the new oil up into the top of the motor. Perfectly normal. It goes away because the pressure in the system when the motor stops keeps the supply path from draining back into the pan.
  13. Rebound
    3,996
    2,644
    Portland, OR
    This is different: If you start a Prius when it's cold and then switch it off right away, if the engine runs only a few seconds, then the next time you start it, even if it's the next day, the engine will shudder and shake a lot.
  14. hc167
    hc167 Member
    132
    US
    Thanks. I never know that. I have never had this happen to my second generation Prius.
  15. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Probably because you started the engine and shut it off before the engine warm up no worries my friend
    Rebound likes this.
