Prius exhaust system
Discussion in 'Gen 2 Prius Main Forum' started by theoriginalwheelstv, Apr 3, 2008.
  1. ravenmaniac
    ravenmaniac Senior Executive VP of Nothing
    156
    DC Metro Area
    Do you think that Toyota would build a vehicle that would be sub-par in this area? Considering how advanced the Prius is, I doubt that something as basic as an exhaust would be overlooked. I'm sure it is built to last.
  2. pashadc
    pashadc Pasha DC
    Washington, DC
    My exhaust is stainless steel lined with sod which uses the excess water to grow the seeds I place in there. Very green - indeed!
  3. Doc Willie
    1,717
    144
    Out there, somewhere
    Mine is constructed of a rodinium-neutronium alloy. Impervious to phaser fire.
  4. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    They were the big supplier until sometime around the 1960's when the deposits played out. Nowadays production (what there is of it) is mostly in East Africa. Production is very limited and often you just can't get any.
  5. tmanson
    tmanson Geetar-playin' Traveler
    71
    Frederick, MD
    Unavailibilium is just a little more accessible than unobtanium, but both are becoming very expensive in these days of economic slowdown.
  6. landstander
    landstander darling no baka
    108
    A place where the nuts hunt the squirrels
    I thought Unobtanium was a type of CPU! :eek:
  7. wiiawiwb
    wiiawiwb Junior Member
    47
    Wow, what are the chances of that. I'd buy a Powerball Lottery ticket!
  8. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Has anyone needed to replace the exhaust system in the second generation Prius? If so, at what mileage. I have almost 86,000 on my '04 and all is well.
    PA P
  9. Patrick Wong
    18,210
    6,515
    The 2G system seems quite reliable; I haven't noticed posts reporting exhaust system replacement.
    Higher-mileage Classic Prius sometimes need new catalytic converters because the HCAC (hydrocarbon absorption chamber) valve becomes sticky, especially in areas where salt is applied on the roads in the winter.
    For 2G, that fancy and unreliable HCAC assembly was removed. The engine coolant heat recovery system took its place.
