prius false code issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John NeSmith, Jul 9, 2015.
  1. John NeSmith
    John NeSmith New Member
    Jesup, Ga.
    My 05 prius was recently in a low speed front end collision. Once the body work was done we tried to drive it and had 2 codes. One was throttle body code and the other was hybrid battery code. We replaced the throttle body and the hybrid battery but still getting the codes. The car drives as it should. Help?
    52,400
    welcome! who did the parts replacements?
  3. John NeSmith
    Jesup, Ga.
    The body shop replaced the throttle body and High Voltage Solutionz replaced the battery.
    52,400
    you can try disconnecting the 12 volt battery for a few minutes. if that doesn't work, you probably need someone with a code reader to reset it. i'm surprised the body shoppe or battery guys couldn't do it.
  5. John NeSmith
    Jesup, Ga.
    We have reset the codes and they keep coming back
  6. John NeSmith
    Jesup, Ga.
    How do I determine if the sensors are working properly and if the problem is the sensor or the wiring to the sensor?
  7. John NeSmith
    Jesup, Ga.
    Also can the sensors be disabled?
  8. Mendel Leisk
    41,925
    There's a thread on the High Voltage Solutionz here:
    Hybrid Battery Replacement... to your door | Page 3 | PriusChat
    You know, it seems like Prius in general don't take well to being in shops, for any reason. There was a lady here, had her car in for tinting, and got it back basically broken. No firm resolution, could even have been water used by the film installers, shorting out a computer.
    Anyway, good luck, hope it gets resolved. I'd bet it's battery related.
  9. bisco
    52,400
    i have to wonder if either one of those actually needed replacing, or if the collision damaged a computer or connection. both were fine before the low speed collision? doesn't seem like either are items that would be damaged.
  10. John NeSmith
    Jesup, Ga.
  11. bisco
    52,400
    i think you're gong to have to take it to toyota for an analysis.
