Prius Fast Tirewear - Important Update
Discussion in 'Gen 2 Prius Main Forum' started by Bob Hayes, Apr 17, 2008.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That doesn't happen with the Integrity tires. I recently measured all 4 tires and the tread wear was pretty even and there was even a tiny bit more tread in the center than on the edges. This was a very small amount of tread difference overall. I've ran over 44psi for more of the tire life and I've ran over 58psi for at least the last 10k miles. I now run 66/64psi. My tires have over 30k on them.
  2. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    I estimated a 5-10% fuel economy hit when they were new. I'm confident I've regained some of that now that they are well broken-in, but it's impossible to quantify it.
  3. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    You folks who are getting good mileage from your OE Integritys, please mention your tire pressures. That is probably the key to getting the maximum wear out of these tires.
  4. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    i sent a fax to the service manager its only been 12 hours or so, so he probably hasn't had time to respond to it.
    the service advisor at the dealership just said ' ill have someone measure them ' and visually looked at them and said they probably look like they are wearing fine, without actually looking under the fenders!! well anyway they don't seem to help me, they
    want me to get the actual warranty paperwork and call bridgestone and have it looked at a real tire store, and not the dealership, which for some strange reason actually sells tires!!!!!
  5. bac
    bac Active Member
    863
    52
    Pennsylvania
    Holy cow! :eek:
    ... Brad
  6. landstander
    landstander darling no baka
    108
    A place where the nuts hunt the squirrels
    Not noticeably. Before the switch I was regularly getting 50-54 MPG on the interstates/highways... primarily driven with the cruise control set to 65 MPH. I'm still hitting the exact same range today. In-town driving seems similarly unaffected, although that case is more difficult to pin down since the mileage is a bit more variable just in general.
    In both cases, the tires were inflated to 40/38 PSI.
  7. rfred
    rfred New Member
    137
    Overland Park, KS
    Gosh, somebody who's actually in the running for a Darwin Award!
  8. rigormortis
    1,340
    26
    san jose, ca
    it looks like im going to strike out
    the dealership won't help me and the tire store called bridegestone up and they say
    there is NO MILEAGE warranties on OEM tires. if you purchase a set from a retailer then you can get some kind of adjustment, but if the tires came with the car
    and your tread wears down a little to fast your not covered
  9. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I've been running pressure about about 44 PSI almost since new and now have 32,000 miles. These integrities will be completely bald on the outside treads by the end of summer with a tad left in the center in the tire on all 4. Only been rotated twice though.
  10. MagneticGrayIndy
    MagneticGrayIndy 06Prius;94M Miata;65Rambler770
    208
    Indianapolis
    hmm.. had never read about this before and went out to check my oem tires. They do seem to be worn more than they should for only 22k miles... but not unevenly or bad yet.
  11. MT-IL
    MT-IL New Member
    I run them about 38 to 40 psi.
    I'm over 78k on the originals now. My commute of 130 miles a day ended and now I'm closer to 30 miles a day so it's taking me longer to get to that 80k mark. I'll probably change the tires out in November so I get it done before it starts snowing.
    I'm probably self defeating since I read an article on the new sites where tire prices are going sky high. I'd probably been more economical to get new tires 3 months ago.
    Anywhoo... still rolling past 78k on the originals... (feb 2006 to now).
  12. GatorJZ
    GatorJZ Member
    285
    17
  13. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I just rotated my OEM Goodyears last night at 60,500 miles. I'm on a 10K rotation, though I slipped a little this time. Both the drivers sides are showing outside corner wear (from each sharing a left front position for 60,000 + miles). The tread wear bars are still not showing, and I feel I could get 10-20K more without trying too hard. My driving is 95% freeway, 450 miles a week, and I have had pressures in the 40/38 range, though last night I bumped them to 42/40, as a response to raising gas prices (what else is new?). It is possible tio get decent mileage out od the OEMs, though it seems some luck is involved. I've never had the alighment checked, and we get very little rain and no snow in LA. I think the long freeway mileages do help the tire wear, as well as proper inflation. I'm looking at Michelein Exalto AS next time around, but I wonder if the Goodyears will actually wear out.
  14. tochatihu
    tochatihu Senior Member
    9,982
    3,851
    Kunming Yunnan China
    2001 Prius
    I don't think that PriusChat has ever had "what is your tire psi?" or "how long did your OEM tires last?" polls. (hint)
  15. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    hmmm gas goes up oil goes up rubber goes up tires go up! Tires are gonna get more expensive by a lot.
  16. Fuzzy
    Fuzzy Junior Member
    17
    I can't say I'm getting good wear from my OEM GY Integrities, probably typical, though. We're nearing 35K (on our '07) and will soon be shopping for new tires. I run the recommended 35F/33R PSI, and rotate almost at recommended intervals (front does wear faster). Where we live (Florida Keys, lots of nails everywhere from lotsa hurricanes past few years) we tend to pick up a lot of nails and have punctures fixed a lot. When the tread gets thin, it's amazing how tiny a nail (or staple) will puncture a tire.
    BTW - The low-tire indicators are great -- never had a false alarm from them. When they say a tire is low, we've found a nail in a tire every time; the warning light has saved us from having to change to the spare on the road a bunch of times.
    I'm guessing that the type of pavement surface must have a lot to do with tire wear -- nothing else could explain how some folks get 60k+ from the Integrities. Poorly-maintained rough asphalt down here.
    The 35k from the OEMs on the Prius beats hell out of 14k on the Toyota Matrix we traded in on the Prius. The Matrix is truly a tire-eater, at least ours was (and we found we were not alone), and Toyota wouldn't own up to a problem... but that's another story.:cool:
  17. Five5Six
    Five5Six New Member
    56
    Los Osos, CA
    I was washing my car yesterday and I could have swore it said max PSI of 44. Running 66/64 seems like it would be pretty dangerous? :confused:
  18. Optimus
    Optimus Member
    274
    25
    Agreed. F8L, can you elaborate a bit on running 66/64psi??? Even heavy duty truck tires are typically only 50psi max.
  19. hill
    9,038
    Yep. Thread rehash. Our Integritys lasted barely over12K miles. Low pressure and hard cornering probably enabled the quick wear too, done by our car's original owner. Now, w/ over 50K on the Hydroedges? You can't even tell if wear has begun yet.
  20. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    No, heavy duty truck tires nowadays are more like 110 psi. One
    hundred and ten, not a typo.
    _H*
