Prius FE Answers buried in the EPA Test Car Database
Discussion in 'Gen 4 Prius Fuel Economy' started by krousdb, Feb 27, 2016.
  1. Naples
    Naples New Member
    Thanks again for your analysis. FYI - I work for EPA in the early seventies and witness some of the early testing on dynamometers. We found the first defeat devices ...Sorry. A brief stroll down memory lane!
    51,848
    worked and witnessed. no need to apologize, we're all cheaters, in one way or another.:)
  3. Naples
    Naples New Member
    One last question.
    Can you determine from the data whether the FE penalty would also affect the Four (non-touring)? The four has a few safety feature and convenience features that are interesting as well as fake leather seats while still useing 15 inch wheels. Another last question, do think that adding the safety option package would add enough additional weight to affect FE?
    I guess what I'd like to know is whether the FE penalty is mostly from the 17 inch wheels or if the weight of the additional options is a significant contributing factor.
    I want my toys and my FE, too.
  4. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    I can't see why options would make a noticeable difference. The non-Eco models are in the 3250 weight class. That means that there cannot be more than 125 lbs difference between the lightest and heaviest cars, otherwise some would be in the 3375 lb class. I have heard of a rule of thumb that says 100 lbs extra weight equals about 1 MPG. If that is true, there might be 1 MPG between the Two and the loaded Three or Four with 15" wheels.
  5. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    One of the unanswered questions is why the 17" wheels look to underperform on MPGs.
    Is it their weight?
    The extra 20MM of rubber on the road? More wind resistance cause by the 10% wider tire width? The different suspension on the Touring models?
    Or perhaps it is the brand/class of the tire itself?
    If it is the brand/class of tire (which I suspect could be a huge factor), could some of the penalty be recaptured when it comes time to buy new tires? Do they even make a lower rolling resistance P215/45/17 tires? Perhaps tires with the similar mileage/tread life/noise/performance characteristics of those which come with the other models? Are the 15" tires equal or superior on all those metrics to the 17"?
    Regardless, shame on Toyota for making this discussion possible -- and kudos to krousdb for the same reason!
  6. bwilson4web
    16,196
    Yes by the inertial mass. The wheel has a substantial amount of mass moved out 2" in diameter. The inertial mass (i.e., spinning momentum) increases by the 4th power of the diameter. Also, the 17" tires weigh more with the mass again further out, again the 4th power of the diameter.
    Now there is a smaller increase in the linear momentum due to the absolute weight of the wheel and tire but we're talking small potatoes. It is the spinning mass that kills efficiency especially when it leads to more brake losses.
    FYI, I use this with our 2003 Prius to increase linear stability in our 2003 Prius. By mounting over-sized, tires the increased moment of inertia (i.e., gyroscopic forces) has fixed the neutral stability problem.
    eric1234 and ATHiker like this.
  7. tzx4
    tzx4 Active Member
    164
    148
    CR must drive very aggressively in their city tests. I could get 60-70's mpg in my '13 Prius c going with the flow around Denver. CR got 44mpg in their city tests. Obviously they spent a fair amount of time with the pedal to the metal, and then they bitched about motor noise. Well, duh . . . .
    Trollbait and bwilson4web like this.
  8. tzx4
    tzx4 Active Member
    164
    148
    Ive said this on another thread here, I read a British website that said that Toyota offers the 15" on all trims because their government CO2 emissions test show that the 17's produce 83 grams C)2/kilometer vs some mid 70's grams with the 15's, and that complies with some sort of driving restriction rule there.
    Pretty obvious that the 17's are not so LRR.
    bwilson4web likes this.
  9. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    For Gen3, CR got (approx numbers) 33 city 55 Hwy (44 avg)...the 33 is other-worldly (way too low) but they seem to hit other cars with the same crazy brush
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If all your braking was pedal to the metal panic stops, you would lose all the regent. It would hurt all hybrids worse than conventional cars
    Trollbait likes this.
  11. Grus
    Grus Member
    79
    China
